{"product_id":"hollyland-cosmo-c2-hdmi-sdi-wireless-video-transmission-system-2-tx-with-1-rx","title":"Hollyland Cosmo C2 HDMI\/SDI Wireless Video Transmission System 2 TX with 1 RX","description":"\u003cdiv\u003e\n\u003cp\u003eFeatures\u003c\/p\u003e \u003cul\u003e \u003cli\u003eWireless Video Transmitter\/Receiver Set\u003c\/li\u003e \u003cli\u003eTransmitter: HDMI\/SDI In, SDI Loop Out\u003c\/li\u003e \u003cli\u003eReceiver: 2 HDMI\/SDI Outputs\u003c\/li\u003e \u003cli\u003e1000m Line-of-Sight 1080p60 Transmission\u003c\/li\u003e \u003cli\u003e5.1 to 5.85 GHz Frequency Bands\u003c\/li\u003e \u003cli\u003eSupports UVC, RTMP \u0026amp; NDI|HX Streaming\u003c\/li\u003e \u003cli\u003eFPS Booster Converts Frame Rates\u003c\/li\u003e \u003cli\u003eHEVO 2.0 Technology, 33 ms Latency\u003c\/li\u003e \u003cli\u003eDC Input, L-Series Battery Plate and V mount on RX.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eThe \u003cstrong\u003eHollyland Cosmo C2 HDMI\/SDI Wireless Video Transmission System\u003c\/strong\u003e enables seamless, long-range \u003cstrong\u003e1080p60 video transmission\u003c\/strong\u003e up to \u003cb\u003e1000m\u003c\/b\u003e to a single receiver, providing flexible monitoring and distribution for both studio and field productions. Operating within the \u003cstrong\u003e5.1 to 5.85 GHz\u003c\/strong\u003e wireless frequency range, this kit includes a transmitter and receiver for reliable, high-quality signal transmission. Enhancements to the series include \u003cstrong\u003eHEVO 2.0 technology\u003c\/strong\u003e, support for \u003cstrong\u003eUVC, RTMP, and NDI|HX streaming\u003c\/strong\u003e, and expanded \u003cstrong\u003epower options\u003c\/strong\u003e for greater versatility.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eStrong Signal Strength, Seamless Frequency Hopping\u003c\/p\u003e \u003cp\u003eThe Cosmo C2 can transmit 1080p60 video up to 1000m line-of-sight with a low 33 ms latency. The system operates on the 5 GHz frequency band, automatically detecting surrounding frequency interference and seamlessly switching to a clean channel via HEVO 2.0 technology. This makes for an uninterrupted transmission signal.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eConnectivity\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThe transmitter features one HDMI input, one SDI input, and one SDI loop output.\u003c\/li\u003e \u003cli\u003eThe receiver features two HDMI outputs, two SDI outputs, and an RJ45 Ethernet port.\u003c\/li\u003e \u003cli\u003eUSB-C ports on both units allow you to connect to the included USB-C OTG adapter and your personal computer for UVC streaming.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eRTMP and NDI|HX Streaming\u003c\/p\u003e \u003cp\u003eThe Cosmo C2 unlocks RTMP streaming for direct live streaming to YouTube, Twitch, and other platforms. The receiver unit supports NDI|HX protocol, transmitting video streams via a single network cable for a cleaner production space.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eFPS Booster, Fractional Frame Rate\u003c\/p\u003e \u003cp\u003eUsing a frame rate compensation algorithm, the Cosmo C2 receiver can convert low frame rate inputs like 1080p24\/25\/30 to high frame rate outputs at 1080p60, making smoother visuals. The Cosmo C2 can also transmit HDMI\/SDI fractional frame rate input\/output signals to ensure flexibility while filming.\u003c\/p\u003e \u003cp\u003eFrozen Frame\u003c\/p\u003e \u003cp\u003eIf your transmission is interrupted, Cosmo C2 can freeze the last frame of your feed, effectively preventing the display of the manufacturer's logo. There is also the option to customize the logo image if you prefer to use a USB flash drive for a more professional appearance.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eVersatile Power and Mounting Options\u003c\/p\u003e \u003cp\u003eEach unit can be powered via DC input using the included power supply when working on set. In field applications or in studio spaces with limited outlets, both units offer battery plate options. The transmitter features an L-series battery plate, and the receiver features a V-mount battery plate for higher-capacity power sources. Use the 1\/4\"-20 threads on the units or the cold shoe adapter to secure them to the mounting configurations of your choice.\u003c\/p\u003e \u003cp\u003eSpecs:\u003c\/p\u003e \u003cp\u003eSpecs\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eVideo I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 1x HDMI 1.4b Input\u003cbr\u003e Transmitter: 1x BNC (3G-SDI) Input\u003cbr\u003e Transmitter: 1x BNC (3G-SDI) Loop Output\u003cbr\u003e Receiver: 2x HDMI 1.4b Output\u003cbr\u003e Receiver: 2x BNC (3G-SDI) Output\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEmbedded Audio\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHDMI\/SDI\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eLatency\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e33 ms\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eVideo Format\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHDMI\/SDI\u003c\/b\u003e\u003cbr\u003e 1080p: 60\/59.94\/50\/30\/29.97\/25\/24\/23.98\u003cbr\u003e 1080i: 60\/59.94\/50\u003cbr\u003e 720p: 60\/59.94\/50\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eBattery Type\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 1x L-Series\u003cbr\u003e Receiver: 1x V-Mount\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003ePower Consumption\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 10 W\u003cbr\u003e Receiver: 11 W\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMounting\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter\/Receiver: 1\/4\"-20 Female (Bottom)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eInputs\/Outputs\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eAntenna I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter\/Receiver: 2x RP-SMA\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eVideo I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 1x HDMI 1.4b Input\u003cbr\u003e Transmitter: 1x BNC (3G-SDI) Input\u003cbr\u003e Transmitter: 1x BNC (3G-SDI) Loop Output\u003cbr\u003e Receiver: 2x HDMI 1.4b Output\u003cbr\u003e Receiver: 2x BNC (3G-SDI) Output\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEmbedded Audio\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHDMI\/SDI\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAudio I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003ePower I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter\/Receiver: 1x Barrel Input\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eOther I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter\/Receiver: 1x USB-C\u003cbr\u003e Receiver: 1x RJ45 (10\/100 Ethernet)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEncryption\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo,\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWireless\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eWireless Range\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e3000' \/ 914.4 m\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eChannel Bandwidth\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e40 MHz\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eFrequency Range\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e5.1 to 5.85 GHz\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eLatency\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e33 ms\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eRF Power\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt; 23 dBm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eRF Sensitivity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e-90 dBm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWi-Fi\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eYes\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eBluetooth\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMobile App Compatible\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eCellular Support\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eFormat Support\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eVideo Format\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHDMI\/SDI\u003c\/b\u003e\u003cbr\u003e 1080p: 60\/59.94\/50\/30\/29.97\/25\/24\/23.98\u003cbr\u003e 1080i: 60\/59.94\/50\u003cbr\u003e 720p: 60\/59.94\/50\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAudio Format\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eTimecode Support\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePower\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eInput Power\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e6 to 16 VDC\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eBattery Type\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 1x L-Series\u003cbr\u003e Receiver: 1x V-Mount\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003ePower Consumption\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 10 W\u003cbr\u003e Receiver: 11 W\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eMounting\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eMounting\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter\/Receiver: 1\/4\"-20 Female (Bottom)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eStatus Display\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eReceiver: LCD\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEnvironmental Resistance\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 114.8 x 69 x 35.5 mm\u003cbr\u003e Receiver: 142 x 87.2 x 33.2 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eTransmitter: 210.00 g\u003cbr\u003e Receiver: 440.00 g\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWhat's in the box:\u003c\/p\u003e \u003cp\u003e1 x Hollyland Cosmo C2 Receiver\u003c\/p\u003e \u003cp\u003e2 x Hollyland Cosmo C2 Transmitter\u003c\/p\u003e \u003cp\u003e1 x USB-C OTG Adaptor\u003c\/p\u003e \u003cp\u003e1 x Cold Shoe Mount\u003c\/p\u003e \u003cp\u003e1 x Power Adaptor (Australia Standard)\u003c\/p\u003e \u003cp\u003e1 x Hard Shell Carry Case\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653296754907,"sku":"COSMOC2-1RX2TX","price":2285.0,"currency_code":"AUD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/CosmoC2-1RX2TX_ad293ead-9de8-4459-828a-44508a1a0999.png?v=1791965878","url":"https:\/\/au.hollyland.com\/products\/hollyland-cosmo-c2-hdmi-sdi-wireless-video-transmission-system-2-tx-with-1-rx","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
