{"product_id":"hollyland-lark-m2s-duo-2-person-wireless-microphone-system-with-usb-c-connector-for-mobile-devices-2-4-ghz-space-gray","title":"Hollyland LARK M2S DUO 2-Person Wireless Microphone System with USB-C Connector for Mobile Devices (2.4 GHz, Space Gray)","description":"\u003cdiv\u003e\n\u003cp\u003e Features\u003c\/p\u003e \u003cul\u003e \u003cli\u003eFor Mobile Journalism, Content Creation\u003c\/li\u003e \u003cli\u003e2 x Ultracompact Transmitters with Mics\u003c\/li\u003e \u003cli\u003eUSB-C Plug-In Receiver\u003c\/li\u003e \u003cli\u003eUp to 1000' Transmission Distance\u003c\/li\u003e \u003cli\u003e48 kHz, 24-Bit Audio Sampling\u003c\/li\u003e \u003cli\u003eEnvironmental Noise Cancellation\u003c\/li\u003e \u003cli\u003eLED Indicators, Built-In Batteries\u003c\/li\u003e \u003cli\u003eiOS\/Android App Control\u003c\/li\u003e \u003cli\u003eIncluded Charging Case\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eRecord up to two people in mobile journalism or content creation applications using this \u003cb\u003eLARK M2S DUO Wireless Microphone System\u003c\/b\u003e from \u003cb\u003eHollyland\u003c\/b\u003e. The system includes two ultracompact transmitters with built-in omnidirectional microphones for discreet recording, a USB-C plug-in receiver for direct connection with mobile devices, and a charging case. The transmitters feature a titanium clip-on design to attach securely to your talent and do not have visible logos for a low-profile appearance.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eStable Audio Transmission\u003c\/p\u003e \u003cp\u003eThe LARK M2S transmitters are engineered with RF interference-resistant circuits for pristine sound quality in most environments. Audio is transmitted via 2.4 GHz frequency up to 1000' away. Easily capture 24-bit, 48 kHz audio with a 70 dB signal-to-noise ratio and 116 dB SPL. Toggle environmental noise cancellation using the transmitters' onboard controls for clear audio capture in loud spaces. Included windscreens improve audio quality outdoors.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003ePlug-In Receiver\u003c\/p\u003e \u003cp\u003eThe USB-C plug-in receiver is compatible with iOS and Android devices. It runs on plug-in power from your connected device and features LED indicators to show the mode status of each transmitter unit.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eLarkSound App\u003c\/p\u003e \u003cp\u003eConnect your LARK M2S system to the LarkSound App to adjust parameters like volume and noise cancellation, update firmware, or check real-time audio status-all from your iOS or Android compatible smartphone. Your smartphone can also playback your recordings when connected to the receiver without needing to unplug it.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eLong Battery Life, Charging Case\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThe transmitters feature 85mAh internal batteries with 9-hour battery life. Once depleted, recharge the components in the included charging case in less than 1.5 hours or via USB-C in 1 hour.\u003c\/li\u003e \u003cli\u003eThe charging case is specifically designed to accommodate the plug-in receiver and two transmitter units. Its 680mAh internal battery can recharge the entire system multiple times for a total battery life of 30 hours.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eWhat's in the box:\u003c\/p\u003e \u003cp\u003e2 x Hollyland Lark M2S Micrephone\u003c\/p\u003e \u003cp\u003e1 x Hollyland Lark M2S USB-C Plug for the Phone\u003c\/p\u003e \u003cp\u003e1 x Hollyland LArk M2S Charging Case\u003c\/p\u003e \u003cp\u003e2 x WindScreen\u003c\/p\u003e \u003cp\u003e1 x USB Cable (USB-A to USB-C) \u003c\/p\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653546381531,"sku":"LARKM2S-DUOC","price":159.0,"currency_code":"AUD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/LarkM2S-DuoC.jpg?v=1791966335","url":"https:\/\/au.hollyland.com\/products\/hollyland-lark-m2s-duo-2-person-wireless-microphone-system-with-usb-c-connector-for-mobile-devices-2-4-ghz-space-gray","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
