{"product_id":"hollyland-lark-max-2-clip-on-wireless-microphone-transmitter-space-gray-2-4-ghz","title":"Hollyland LARK MAX 2 Clip-On Wireless Microphone Transmitter (Space Gray, 2.4 GHz)","description":"\u003cdiv\u003e\n\u003cp\u003eThe \u003cstrong\u003eLARK MAX 2\u003c\/strong\u003e transmitter\/microphone is designed with both form and function in mind. Its sleek, low-profile body allows for discreet, versatile placement using the included hidden magnetic clip—perfect for on-camera talent or fast-paced productions. A furry windshield and a convenient charging dock are also included to ensure optimal audio performance and maximum convenience.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003e32-Bit Float Recording with Timecode Sync\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eCapture every detail with confidence. The LARK MAX 2 features a built-in recorder that utilizes \u003cstrong\u003e32-bit float technology\u003c\/strong\u003e, delivering pristine audio with an exceptionally wide dynamic range. This advanced format virtually eliminates digital clipping and allows low-volume recordings to be safely amplified without introducing noise—ensuring clean, professional results every time.\u003c\/p\u003e \u003cp\u003eWith \u003cstrong\u003e8GB of internal storage\u003c\/strong\u003e, the transmitter can record up to \u003cstrong\u003e14 hours\u003c\/strong\u003e of uncompressed, high-resolution audio, making it a dependable backup solution in any shooting environment. Even when wireless transmission is disrupted or unavailable, the LARK MAX 2 functions as a \u003cstrong\u003estandalone recorder\u003c\/strong\u003e, ideal for remote shoots, events, and high-stakes interviews.\u003c\/p\u003e \u003cp\u003eAn integrated, \u003cstrong\u003eframe-accurate timecode system\u003c\/strong\u003e allows for seamless syncing between recorded audio and video footage, eliminating the need for manual alignment in post-production and streamlining your workflow from shoot to edit.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eFeatherlight Comfort Meets Modern Style\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eWeighing just \u003cstrong\u003e0.5 oz (14 g)\u003c\/strong\u003e and measuring a mere \u003cstrong\u003e0.4 inches thin\u003c\/strong\u003e, the LARK MAX 2 is built to blend effortlessly into any outfit. Its ultra-slim profile won’t tug on fabric or disrupt your appearance, making it ideal for interviews, podcasts, vlogging, and more.\u003c\/p\u003e \u003cp\u003eThe innovative \u003cstrong\u003ehover-clip mechanism\u003c\/strong\u003e replaces bulky spring clips with a secure, magnetic push-and-pull design—enabling fast, precise placement with minimal effort. Whether mounted on a lapel, collar, or hidden under clothing, the LARK MAX 2 stays comfortably in place.\u003c\/p\u003e \u003cp\u003eEngineered for long-wear sessions, the transmitter features a \u003cstrong\u003eskin-friendly, excimer nano-coated finish\u003c\/strong\u003e, offering a smooth and soft touch against the skin—perfect for extended shoots or live events.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eIntuitive One-Touch Control\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eTake control with a tap. The LARK MAX 2 keeps essential functions right at your fingertips:\u003c\/p\u003e \u003cul\u003e \u003cli\u003e \u003cp\u003e\u003cstrong\u003eOn\/Off Button:\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e \u003cp\u003eSingle press: Activates noise cancellation\u003c\/p\u003e \u003c\/li\u003e \u003cli\u003e \u003cp\u003eDouble press: Mutes the microphone\u003c\/p\u003e \u003c\/li\u003e \u003c\/ul\u003e \u003c\/li\u003e \u003cli\u003e \u003cp\u003e\u003cstrong\u003eREC Button:\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e \u003cp\u003eSingle press: Starts onboard recording\u003c\/p\u003e \u003c\/li\u003e \u003c\/ul\u003e \u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eSimple, responsive, and built for creators on the move, the LARK MAX 2 ensures you're always ready to capture the moment—clearly, cleanly, and effortlessly.\u003c\/p\u003e \u003cp\u003eWhat's included:\u003c\/p\u003e \u003cp\u003e 1 x Transmitter\u003cbr\u003e 1 x Furry Windfield\u003cbr\u003e 1 x USB-C to USB-C Cable\u003cbr\u003e 1 x USB-C to 3.5mm Adapter\u003cbr\u003e 1 x Magnetic Silicone Sleeve\u003cbr\u003e 1 x Magnet\u003cbr\u003e \u003c\/p\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653545955547,"sku":"LARKMAX2TX","price":112.0,"currency_code":"AUD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/LarkMax2TX_e9dc44df-484a-402f-91b9-7aecdfbd1afb.jpg?v=1791966333","url":"https:\/\/au.hollyland.com\/products\/hollyland-lark-max-2-clip-on-wireless-microphone-transmitter-space-gray-2-4-ghz","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
