{"product_id":"hollyland-solidcom-c1-pro-4s-wireless-intercom-system-with-4-enc-wireless-headsets","title":"Hollyland Solidcom C1 Pro 4S Wireless Intercom System With 4 ENC Wireless Headsets","description":"\u003cdiv\u003e\n\u003cp\u003eFeaturing dual-mic Environmental Noise Cancellation (ENC) for use in loud environments, the \u003cstrong\u003eHollyland Solidcom C1 Pro-4S\u003c\/strong\u003e is a full-duplex wireless DECT intercom system engineered to provide clear audio and all-day wearing comfort in a true-wireless design with no bodypack or hub required. This configuration includes 4 single-sided headsets, 1 master and 3 remotes, along with rechargeable batteries, a charger, and accessories. The system transmits in the 1.9 GHz spectrum and uses proven DECT 6.0 technology to ensure secure and reliable transmission at a line-of-sight range of up to 1100'—making it well suited for a variety of applications including film\/TV production, concerts, and live events.\u003c\/p\u003e \u003carticle\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eDual-Mic Environmental Noise Cancellation\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eFor clear communication in loud environments, engage the dual-mic ENC (Environmental Noise Cancellation) feature. The ENC algorithm combines the main directional microphone at the speaker's mouth with a secondary omnidirectional environmental mic on the earcup to cancel out unwanted background noise for more intelligible speech. The microphone's wide 150 Hz to 7 kHz frequency response ensures detailed voice capture to keep your team working efficiently.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003eLED shows that the system is working, with different colors representing different operating states. Blue LED is steady, indicating that ENC noise reduction is turned on. Green LED is steady, indicating that ENC noise reduction is turned off. Red LED is steady, indicating that the microphone is off.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eTrue-Wireless Self-Contained Headset for 2-Way Communication\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eWith no beltpack or base station, the C1 Pro offers a highly portable and hands-free coordinating experience for media production teams and others looking for real-time voice communication at line-of-sight distances up to 1100'. The Pro version offers increased portability and durability over the original, while the single-ear headset design is dust and water resistant and designed to provide a comfortable all-day wearing experience.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eEasy to Use\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eA long press on the \"A\" button on the master and remote headsets is all it takes; the headsets pair up in about 10 seconds and you're good to go. The microphone boom on each headset rotates 360°, allowing for left or right orientation. Rotating the boom arm up or down conveniently mutes the mic when not in use. Alternatively, the mute button on the earcup can be set to mute or push to talk, depending on the user's preference. An LED indicates the system is working and warns you when the battery is low.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eRechargeable Batteries + Charging Station\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eEach headset runs on a single rechargeable battery. The amount of battery time in the master headset depends on the number of following headsets in use; with 1 to 5 remote headsets connected and the ENC features engaged, the battery will last for approximately 5 hours; with up to 7 following headsets in use, the battery life is 4 hours. Each remote headset will last for up to 10 hours on a single battery charge with the ENC engaged. Each battery fully recharges in 2.5 hours and a battery charging station, USB cable, and AC adapter are included.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eIncreased Portability \u0026amp; Durability for a Better Experience\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eThe Solidcom C1 Pro headset is crafted using PC-ABS materials, making it incredibly lightweight-a mere 170g (6oz) with the battery included and super compact. The upgraded over-ear leather cushion better fits the human ear structure for added stability and comfort, perfect for anyone who works in challenging environments. Durable on-ear foam cushions are also provided to address different wearing preferences. Simply use them as needed and enjoy the experience of incredible portability and comfort without compromising quality.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eRobust Wind Noise Removal\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eTroubled by wind noise in outdoor production environments? The Solidcom C1 Pro offers a versatile solution that prevents airflow from directly hitting the mic. With the Y5 felt paper designed for the main mic as the wind filter as well as the microphone cushion, the headset can reduce wind noise by 20.76dB. You can enjoy complete peace of mind in production environments where wind noise is a major challenge.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e\u003c\/p\u003e \u003cp\u003e\u003cu\u003e\u003cstrong\u003eExpandable and Backwards Compatible\u003c\/strong\u003e\u003c\/u\u003e\u003c\/p\u003e \u003cp\u003eThe Solidcom C1 Pro system allows you to link up to 7 remote headsets to the master headset without using a hub. The C1 Pro HUB Base (available separately) lets you use up to 8 remote headsets at once. The C1 Pro is backward-compatible with the Solidcom C1 system. Note that the ENC technology functions by removing the environmental noise at the speaker side. Whether you're wearing a C1 or a C1 Pro, the environmental noise you hear will be significantly reduced as long as the sound is coming from a C1 Pro headset.\u003c\/p\u003e \u003cp\u003e\u003cimg\u003e UPC: 191460003097\u003c\/p\u003e \u003c\/article\u003e \u003caside\u003e \u003ch4\u003e\u003cu\u003e\u003cstrong\u003eItems Included\u003c\/strong\u003e\u003c\/u\u003e\u003c\/h4\u003e \u003cul\u003e \u003cli\u003eHollyland Solidcom C1 Pro-4S Full-Duplex ENC Wireless Intercom System with 4 Headsets (1.9 GHz)\u003c\/li\u003e \u003cli\u003eMaster Headset\u003c\/li\u003e \u003cli\u003e3 x Follower Headset\u003c\/li\u003e \u003cli\u003eCharging Case\u003c\/li\u003e \u003cli\u003e4 x Over-Ear Leather Cushion\u003c\/li\u003e \u003cli\u003e4 x On-Ear Foam Cushion\u003c\/li\u003e \u003cli\u003e4 x Mic Windscreen\u003c\/li\u003e \u003cli\u003e8 x Battery\u003c\/li\u003e \u003cli\u003eUSB Type-A to USB Type-C Cable\u003c\/li\u003e \u003cli\u003ePower Adapter\u003c\/li\u003e \u003cli\u003eStorage Case\u003c\/li\u003e \u003cli\u003eLimited 1-Year Manufacturer Warranty\u003c\/li\u003e \u003c\/ul\u003e \u003c\/aside\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653293805787,"sku":"C1-PRO-4S","price":2359.0,"currency_code":"AUD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/C1-Pro-4S.png?v=1791965873","url":"https:\/\/au.hollyland.com\/products\/hollyland-solidcom-c1-pro-4s-wireless-intercom-system-with-4-enc-wireless-headsets","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
