{"product_id":"hollyland-solidcom-c1-pro-roaming-hub-20s-full-duplex-wireless-intercom-system","title":"Hollyland Solidcom C1 Pro Roaming Hub 20S Full-Duplex Wireless Intercom System","description":"\u003cdiv\u003e\n\u003cp\u003eFeatures\u003c\/p\u003e \u003cul\u003e \u003cli\u003eCommunication for Mobile Production Team\u003c\/li\u003e \u003cli\u003eTwo-Mic Environmental Noise Cancellation\u003c\/li\u003e \u003cli\u003eReliable 1.9 GHz DECT 6.0 Technology\u003c\/li\u003e \u003cli\u003eHub with \u003cstrong\u003eV-Mount\u003c\/strong\u003e for Seamless Roaming\u003c\/li\u003e \u003cli\u003e20 Single-Ear Headsets, Expandable to 20\u003c\/li\u003e \u003cli\u003eWide Frequency Response for Clear Audio\u003c\/li\u003e \u003cli\u003e500m 2-Way Operating Range, App Control\u003c\/li\u003e \u003cli\u003eMute\/PTT Button or Rotate Boom to Mute\u003c\/li\u003e \u003cli\u003eIncludes Headset Batteries \u0026amp; Charger\u003c\/li\u003e \u003cli\u003eBackward Compatible with Solidcom C1\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eDesigned for mobile production teams and featuring dual-mic Environmental Noise Cancellation (ENC) for use in loud environments, the \u003cstrong\u003eHollyland Solidcom C1 Pro Roaming Hub 20S\u003c\/strong\u003e is a full-duplex wireless DECT intercom system with hub engineered to provide clear audio and all-day wearing comfort in a true-wireless design with no bodypack required. This configuration includes 20 single-ear headsets, along with 40 rechargeable batteries, an 8-bay charging station, and accessories.\u003c\/p\u003e \u003cp\u003eThe system transmits in the 1.9 GHz spectrum and uses proven DECT 6.0 technology to ensure secure and reliable transmission at a line-of-sight range of up to 500m—making it well suited for a variety of applications, including film\/TV production, concerts, and live events.\u003c\/p\u003e \u003cp\u003eRoaming Hub with V-Mount and 6 Groups\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThis version of the Solidcom C1 Pro Roaming Hub features a V-mount for use with compatible external batteries, allowing you to take the system anywhere the action leads.\u003c\/li\u003e \u003cli\u003eThe hub provides more communication options with up to 6 groups available, greatly eliminating the possibility of communication interruption and improving team coordination efficiency.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003e20 True-Wireless Single-Ear Headsets for 2-Way Communication\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThe single-ear headset design is dust and water resistant and designed to provide a comfortable all-day wearing experience.\u003c\/li\u003e \u003cli\u003eUsing the Roaming Hub conveniently eliminates the need for a specific master headset.\u003c\/li\u003e \u003cli\u003eFor clear communication in loud environments, engage the dual-mic ENC (Environmental Noise Cancellation) feature.\u003c\/li\u003e \u003cli\u003eThe ENC algorithm combines the main directional microphone at the speaker's mouth with a secondary omnidirectional environmental mic on the earcup to cancel out unwanted background noise for more intelligible speech.\u003c\/li\u003e \u003cli\u003eThe microphone's wide 150 Hz to 7 kHz frequency response ensures detailed voice capture to keep your team working efficiently.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eUAC for Cloud Meetings\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThe USB Audio Class (UAC) function featured on the hub facilitates joining cloud meetings anytime running on Zoom, Skype, or other meeting programs.\u003c\/li\u003e \u003cli\u003eSimply connect your personal computer to the hub via its USB interface. This seamlessly brings your on-site and remote teams together, facilitating team interaction and creativity wherever your teams are located.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eRechargeable Batteries + Charging Station\u003c\/p\u003e \u003cul\u003e \u003cli\u003eEach headset runs on a single rechargeable battery\u003c\/li\u003e \u003cli\u003eEach remote headset will last for up to 10 hours on a single battery charge with the ENC engaged\u003c\/li\u003e \u003cli\u003eEach battery fully recharges in 2.5 hours\u003c\/li\u003e \u003cli\u003eThree 8-bay battery charging stations and AC adapter are included.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eExpandable and Backwards Compatible\u003c\/p\u003e \u003cul\u003e \u003cli\u003eThe Solidcom C1 Pro Roaming Hub system allows you to link up to 20 headsets.\u003c\/li\u003e \u003cli\u003eThe C1 Pro Roaming Hub is backward-compatible with the Solidcom C1 system.\u003c\/li\u003e \u003cli\u003eYou can easily daisy-chain different systems as needed on site to meet even more complex operational requirements.\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eSpecs\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eUsers per System:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e 20\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWireless Technology:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e Digital DECT (1.9 GHz)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eOperating Range:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e 500m\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEncryption:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e Proprietary\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eInputs\/Outputs:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2x RJ45\u003cbr\u003e 1x USB-A\u003cbr\u003e 1x USB-C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEarpiece Design:\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e On-Ear (Supra-Aural) \/ Over-Ear (Circumaural)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eNumber of Earpieces\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eSingle Earpiece (Left or Right Side)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eSystem\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eNumber of Included Headsets: \u003c\/td\u003e \u003ctd\u003e \u003cp\u003e 20x Single-Sided Headset\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eUsers per System\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e20\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWireless Connectivity\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eWireless Technology\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e Digital DECT (1.9 GHz) \u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDECT Standard\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e6.0\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eOperating Range\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e500m\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eRF Bandwidth\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1.73 MHz\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMax Transceivers per Band\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e20\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWireless Modulation\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eAnalog: \u003c\/b\u003eGFSK\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDuplex Mode\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eFull-Duplex (FDX)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eApproximate RF Sensitivity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e-90 dBm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eFrequency\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1920 to 1930 MHz\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEncryption\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eProprietary\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMobile App Compatible\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eYes: Android \u0026amp; iOS\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eBase Station\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eInputs\/Outputs\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2x RJ45\u003cbr\u003e 1x USB-A\u003cbr\u003e 1x USB-C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAntenna\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eBase Station:\u003c\/b\u003e\u003cbr\u003e 4x External, Detachable\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAC\/DC Power Adapter\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e12 VDC (Included)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eHeadphone\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eEarpiece Design\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eOn-Ear (Supra-Aural) \/ Over-Ear (Circumaural)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eEarpiece Connection \/ Wearing Style\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHeadband\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eNumber of Earpieces\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eSingle Earpiece (Left or Right Side)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eSound Field\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eMono\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eControls\/Microphone Location\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eControls: Adjustable Boom, Earpiece (Side Unspecified)\u003cbr\u003e Microphone: Earpiece (Side Unspecified)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eFrequency Response\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e150 Hz to 7 kHz\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eTotal Harmonic Distortion (THD)\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1%\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMaximum Sound Pressure Level (SPL)\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e115 dB\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eSNR\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHeadphones:\u003c\/b\u003e\u003cbr\u003e \u0026gt;71 dB\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eMicrophone\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eMicrophone Type\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eElectret Condenser\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMic Boom Location\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eInterchangeable (Left or Right Side)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003ePickup Pattern\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eCardioid (Unidirectional)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eNoise Cancelling Microphone\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eYes\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMaximum SPL\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e115 dB\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDistortion\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt;1%\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWired Connectivity\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eAudio Connector\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAudio Connector to Earpiece\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo Wired Audio Support\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eBattery\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eBattery Type\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHeadset: \u003c\/b\u003e1 x 26650\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eBattery Chemistry\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHeadset:\u003c\/b\u003eLithium-Ion\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eCapacity (mAh)\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e700 mAh\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eRuntime\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u003cb\u003eHeadset:\u003c\/b\u003e10 Hours\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eRecharge Time\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2.5 Hours\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eEnvironmental\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eOperating Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e-10 to 45°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eStorage Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e-20 to 60°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eContent list:\u003c\/p\u003e \u003cp\u003e1 x Hollyland Solidcom C1 Pro Roaming Hub\u003c\/p\u003e \u003cp\u003e20 x Hollyland Solidcom C1 Pro Single Ear Headset (ENC and NFC on borad)\u003c\/p\u003e \u003cp\u003e40 x Hollyland Solidcom C1 Pro Battery\u003c\/p\u003e \u003cp\u003e3 x Hollyland Solidcom C1 Pro 8 Slot Battery Charger\u003c\/p\u003e \u003cp\u003e4 x Hollyland Solidcom C1 Pro Roaming Hub Antenna\u003c\/p\u003e \u003cp\u003e20 x Hollyland Solidcom C1 Pro Over-Ear Earmuff\u003c\/p\u003e \u003cp\u003e20 x Hollyland Solidcom C1 Pro On-Ear Earmuff\u003c\/p\u003e \u003cp\u003e20 x Hollyland Solidcom C1 Pro Earpad\u003c\/p\u003e \u003cp\u003e20 x Mic Cushion\u003c\/p\u003e \u003cp\u003e1 x Hardshell Carry Case\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653547790555,"sku":"SOLIDCOMROAMING-20S","price":21435.0,"currency_code":"AUD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/SolidcomRoaming-20S_16378564-8626-4da3-9026-27246cc2ce92.jpg?v=1791966336","url":"https:\/\/au.hollyland.com\/products\/hollyland-solidcom-c1-pro-roaming-hub-20s-full-duplex-wireless-intercom-system","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
