{"product_id":"hollyland-solidcom-se-pro-1-9ghz-wireless-intercom-kit-with-5-headsets","title":"Hollyland Solidcom SE Pro 1.9GHz Wireless Intercom Kit with 5 Headsets","description":"\u003cdiv\u003e\n\u003cp\u003eFeatures:\u003c\/p\u003e \u003cul\u003e \u003cli\u003e400m Transmission Range\u003c\/li\u003e \u003cli\u003eDual-Mic Noise Cancellation\u003c\/li\u003e \u003cli\u003eSupports Up to 11 Users\u003c\/li\u003e \u003cli\u003eDependable Mute Control\u003c\/li\u003e \u003cli\u003eDust and Water Resistance\u003c\/li\u003e \u003cli\u003e10-Hour Battery Life\u003c\/li\u003e \u003cli\u003e3.5mm Headphone Supported\u003c\/li\u003e \u003cli\u003eReady Out of Box\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eThe \u003cstrong\u003eSolidcom SE Pro\u003c\/strong\u003e is built for production teams that demand reliable and enhanced communication. Featuring a transmission range of up to \u003cstrong\u003e400 meters\u003c\/strong\u003e, \u003cstrong\u003edual-mic noise cancellation\u003c\/strong\u003e, and support for up to \u003cstrong\u003e11 users\u003c\/strong\u003e, it delivers crystal-clear audio even in challenging environments. With a \u003cstrong\u003e10-hour battery life\u003c\/strong\u003e and \u003cstrong\u003eUSB-C connectivity\u003c\/strong\u003e for convenient charging, it's perfect for fast-paced settings like video production and outdoor events. The system comes \u003cstrong\u003epre-paired for instant setup\u003c\/strong\u003e, and its \u003cstrong\u003ewater-resistant design\u003c\/strong\u003e ensures dependable performance wherever your work takes you.\u003c\/p\u003e \u003ch3\u003e\u003cstrong\u003eUninterrupted Communication, Every Time\u003c\/strong\u003e\u003c\/h3\u003e \u003ch4\u003e\u003cstrong\u003eExtended Transmission Range – Up to 400m\u003c\/strong\u003e\u003c\/h4\u003e \u003cp\u003eStay connected with your team across large distances. The Solidcom SE Pro offers an impressive 400-meter communication range, delivering crystal-clear conversations even in wide and dynamic workspaces.\u003c\/p\u003e \u003ch4\u003e\u003cstrong\u003eAdvanced Interference-Free Connectivity\u003c\/strong\u003e\u003c\/h4\u003e \u003cp\u003e\u003cstrong\u003eAdaptive Frequency Hopping\u003c\/strong\u003e ensures stable performance by automatically avoiding environmental interference. Coupled with operation in the \u003cstrong\u003e1.9GHz band\u003c\/strong\u003e, it effectively minimizes disruptions from crowded 2.4GHz frequencies like Wi-Fi and Bluetooth.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eDual-Mic Noise Cancellation – Pro Sound Sensation\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eCut through the noise with \u003cstrong\u003edual-mic noise cancellation\u003c\/strong\u003e, designed to isolate your voice in the busiest environments. Whether you're on a bustling set or in an open outdoor space, your message comes through loud and clear.\u003c\/p\u003e \u003cp\u003eWith a \u003cstrong\u003ewideband frequency response of 150Hz–7kHz\u003c\/strong\u003e, expect rich, detailed audio that elevates your communication to a truly professional level.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eSupports Up to 11 Users – Scalable for Growing Teams\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eWhether you're starting small or managing a larger crew, the Solidcom SE Pro is ready. With support for up to \u003cstrong\u003e11 users\u003c\/strong\u003e, it's ideal for budget-conscious teams that need flexibility and room to grow.\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003eBattery Life Estimates:\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e \u003cp\u003e\u003cstrong\u003eRemote Headset\u003c\/strong\u003e: Over 10 hours (with noise cancellation enabled)\u003c\/p\u003e \u003c\/li\u003e \u003cli\u003e \u003cp\u003e\u003cstrong\u003eMaster Headset\u003c\/strong\u003e: Over 5 hours (with 5 remote headsets)\u003c\/p\u003e \u003c\/li\u003e \u003cli\u003e \u003cp\u003e\u003cstrong\u003eMaster Headset\u003c\/strong\u003e: Over 4.5 hours (with 7 remote headsets)\u003c\/p\u003e \u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003e\u003cem\u003eNote: The Solidcom SE Pro is not compatible with the Solidcom C1, C1 Pro, or Solidcom SE Global Version.\u003c\/em\u003e\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eDependable Mute Control\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eStay in control with dedicated \u003cstrong\u003eTALK\/MUTE\u003c\/strong\u003e switching and a quick-access \u003cstrong\u003eboom mic mute\u003c\/strong\u003e feature. For hands-free convenience, the \u003cstrong\u003eindustry-standard PTT (Push-to-Talk)\u003c\/strong\u003e mode ensures smooth communication that fits your workflow.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eComprehensive Protection – Built to Withstand the Elements\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eDesigned for real-world use, the Solidcom SE Pro is \u003cstrong\u003edust- and water-resistant\u003c\/strong\u003e, shielding against rain, splashes, and unpredictable conditions. Wherever the job takes you, you can count on solid, uninterrupted communication.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eStay Powered – 10-Hour Battery Life + Hot Swap Convenience\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003eGet through long days with a \u003cstrong\u003e10-hour battery life\u003c\/strong\u003e on each headset. The \u003cstrong\u003edetachable battery design\u003c\/strong\u003e allows for instant hot-swapping — just pop in the spare battery (included) and keep going.\u003c\/p\u003e \u003cp\u003eNeed more flexibility? \u003cstrong\u003eUSB-C charging\u003c\/strong\u003e lets you power up with a wall charger or power bank while still using the headset.\u003c\/p\u003e \u003chr\u003e \u003ch3\u003e\u003cstrong\u003eConnect Your Way – 3.5mm Headphone Compatibility\u003c\/strong\u003e\u003c\/h3\u003e \u003cp\u003ePrefer using your own headphones? The Solidcom SE Pro supports \u003cstrong\u003e3.5mm headphone connection\u003c\/strong\u003e via a \u003cstrong\u003eHollyland USB-C to 3.5mm adapter\u003c\/strong\u003e. Simply wear the headset around your neck and stay connected in comfort.\u003c\/p\u003e \u003cp\u003e\u003cem\u003eNote: Only compatible with the official Hollyland adapter (sold separately).\u003c\/em\u003e\u003c\/p\u003e \u003cp\u003eWhat's in the box:\u003c\/p\u003e \u003cp\u003e1 x Hollyland Solidcom SE Pro 1.9GHz Wireless Master Headset\u003c\/p\u003e \u003cp\u003e4 x Hollyland Solidcom SE Pro 1.9GHz Wireless Remote Headset\u003c\/p\u003e \u003cp\u003e10 x Hollyland Li-ion Battery Pack HL-BAT770\u003c\/p\u003e \u003cp\u003e1 x Hollyland Solidcom SE Pro 6-Slot Charging Base\u003c\/p\u003e \u003cp\u003e1 x Hollyland USB-A to USB-C Cable\u003c\/p\u003e \u003cp\u003e1 x Carry Case\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653546021083,"sku":"HL-SOLIDCOMSEPRO-5S","price":1495.0,"currency_code":"AUD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/HL-SOLIDCOMSEPRO-5S_950f3eda-fb9b-4753-8fb9-98b6f0f2c4fb.jpg?v=1791966333","url":"https:\/\/au.hollyland.com\/products\/hollyland-solidcom-se-pro-1-9ghz-wireless-intercom-kit-with-5-headsets","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
