{"product_id":"hollyland-wireless-tally-system-with-8-tally-lights","title":"Hollyland Wireless Tally System (With 8 Tally Lights)","description":"\u003cdiv\u003e\n\u003cp\u003eFeatures\u003c\/p\u003e \u003cul\u003e \u003cli\u003ePortable Wireless Tally System\u003c\/li\u003e \u003cli\u003e8 Tally Lights Included\u003c\/li\u003e \u003cli\u003eConnect Tally Lights up to 2600' Away\u003c\/li\u003e \u003cli\u003eUp to 16 Channels Supported\u003c\/li\u003e \u003cli\u003eSmart Sequence Learning\u003c\/li\u003e \u003cli\u003eAdaptive Frequency Hopping\u003c\/li\u003e \u003cli\u003eDetachable Battery with 8-Hour Runtime\u003c\/li\u003e \u003cli\u003eDB25, RJ45 \u0026amp; USB-C Connectivity\u003c\/li\u003e \u003cli\u003eTally Light \u0026amp; Battery Weigh Only 3.5 oz\u003c\/li\u003e \u003cli\u003eHard Shell Case Included\u003c\/li\u003e \u003c\/ul\u003e \u003cp\u003eThis \u003cstrong\u003eWireless Tally System\u003c\/strong\u003e from \u003cstrong\u003eHollyland\u003c\/strong\u003e is a portable, complete tally solution that includes eight tally lights that can be connected up to 2600' away from the wireless host unit. Equipped with multiple ports that provide DB25, RJ45, and USB-C connectivity for compatibility with a wide range of switchers, the system boasts a powerful smart sequence learning function, adaptive frequency hopping, and support for up to 16 channels for future expansion of the system.\u003c\/p\u003e \u003cp\u003eThe sequence learning function of the system enables users to easily connect any switcher operating with high or low voltage levels to the system, employing a standard tally cable for wide switcher compatibility. Frequency hopping facilitates the detection of interference, enabling the system to automatically hop to a channel with less interference for a more stable and reliable transmission. A detachable lithium-ion battery pack included with each tally light provides up to eight hours of uninterrupted operation, and a hard-shell case is included for easy transport and storage.\u003c\/p\u003e \u003cp\u003eSpecifications:\u003c\/p\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eCompatibility\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHollyland Wireless Tally System\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMax Transmission Distance\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2600' \/ 800 m\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eSensitivity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt;-115 dBm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDelay\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt;150 ms\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eDisplay\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003ePanel Type\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDisplay Size\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eTouchscreen\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNo\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eInputs \/ Outputs\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eUSB I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1 x USB-A Female Input\/Output\u003cbr\u003e 1 x USB-C Female Input\/Output\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eOther I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1 x RJ45 Port for Tally Input\u003cbr\u003e 1 x RJ45 Port for Switcher Loop Out\u003cbr\u003e 1 x DB25 Port for Tally Input\u003cbr\u003e 2 x Antenna Connector\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWireless\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eWireless\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2.4 GHz Radio\/RF\u003cbr\u003e \u003ci\u003e*Built-In\u003c\/i\u003e\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePower\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003ePower Source\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eAC Adapter with Power Brick (Included)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eEnvironmental\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eOperating Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e32 to 113°F \/ 0 to 45°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eStorage Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e14 to 140°F \/ -10 to 60°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePhysical\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eColor\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eBlack\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e9.2 x 5.6 x 2\" \/ 232.8 x 142.5 x 50.1 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2.6 lb \/ 1.2 kg\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003ch2\u003eHollyland Tally Light Specs\u003c\/h2\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eCompatibility\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHollyland Wireless Tally System\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMax Transmission Distance\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2,600' \/ 800 m\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eSensitivity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt;-115 dBm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDelay\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e\u0026lt;150 ms\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eModulation\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eLORA\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWireless\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eWireless\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e2.4 GHz Radio\/RF\u003cbr\u003e \u003ci\u003e*Built-In\u003c\/i\u003e\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eBattery\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eBattery Chemistry\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eLithium-Ion\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMaximum Battery Life\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e8 Hours\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eEnvironmental\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eOperating Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e32 to 113°F \/ 0 to 45°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eStorage Temperature\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e14 to 140°F \/ -10 to 60°C\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePhysical\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e3.1 x 2 x 1.5\" \/ 77.8 x 50.5 x 37.4 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e3.5 oz \/ 98.5 g (with Battery)\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003ch2\u003eHollyland Hard-Shell Case For Wireless Tally System Specs\u003c\/h2\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eCompatibility\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHollyland Wireless Tally System\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePhysical\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eColor\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eBlack\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e20.3 x 13.8 x 8.5\" \/ 515 x 350 x 215 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003ch2\u003eHollyland Antenna For Wireless Tally System (Pair) Specs\u003c\/h2\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eCompatibility\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHollyland Wireless Tally System\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eGain\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e4 dBi\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePhysical\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eColor\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eBlack\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e10.4 x 3.9 x 1\" \/ 265 x 100 x 25 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e4.1 oz \/ 115 g\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003ch2\u003eHollyland 12V 2A DC 2.1mm Power Adapter Specs\u003c\/h2\u003e \u003cp\u003eGeneral\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eCompatibility\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eHollyland Wireless Tally System\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePower\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003ePower Source\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eAC Adapter with Power Brick\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003ePower I\/O\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1x Barrel Output\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eCenter Tip Polarity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eAC Input Power\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDC Input Power\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e12 VDC at 2 A\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eMaximum Power Output\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eNot Specified by Manufacturer\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003ePhysical\u003c\/p\u003e \u003ctable\u003e \u003ctbody\u003e \u003ctr\u003e \u003ctd\u003eQuantity\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e1\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eColor\u003c\/td\u003e \u003ctd\u003e \u003cp\u003eBlack\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eDimensions\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e8.5 x 5.2 x 0\" \/ 215 x 132 x 0.1 mm\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003ctr\u003e \u003ctd\u003eWeight\u003c\/td\u003e \u003ctd\u003e \u003cp\u003e5.29 oz \/ 150 g\u003c\/p\u003e \u003c\/td\u003e \u003c\/tr\u003e \u003c\/tbody\u003e \u003c\/table\u003e \u003cp\u003eWhat's in the box:\u003c\/p\u003e \u003cp\u003e1 x Hollyland Tally Station\u003c\/p\u003e \u003cp\u003e8 x Hollyland Tally Light\u003c\/p\u003e \u003cp\u003e8 x Battery\u003c\/p\u003e \u003cp\u003e1 x Battery Charger\u003c\/p\u003e \u003cp\u003e1 x Carry Case\u003c\/p\u003e \u003c\/div\u003e","brand":"Hollyland","offers":[{"title":"Default Title","offer_id":50653545988315,"sku":"WIRELESSTALLYSYSTEM8","price":1758.0,"currency_code":"AUD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/WirelessTallySystem8_9544b0bd-0c40-4d98-b725-885d5ae056c5.jpg?v=1791966333","url":"https:\/\/au.hollyland.com\/products\/hollyland-wireless-tally-system-with-8-tally-lights","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
