{"product_id":"lark-a2","title":"LARK A2","description":"\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eFeature\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e48kHz\/24 Bit\u003c\/li\u003e\n\u003cli\u003eAI Noise Cancellation\u003c\/li\u003e\n\u003cli\u003eQuick Charging \u003c\/li\u003e\n\u003cli\u003eClip-and-Go\u003c\/li\u003e\n\u003cli\u003eAI Voice Tuning\u003c\/li\u003e\n\u003cli\u003eAI Auto-Limit Clip \u003c\/li\u003e\n\u003cli\u003eSafety Track\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eDescription\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eCreate with confidence, wherever your ideas take you. LARK A2 keeps your voice clear in any environment with AI noise cancellation and keeps pace with your day through intelligent power saving. With a more natural voice-driven workflow for Vibe Coding, just clip it on, speak your ideas, and stay focused on creating.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【AI-Managed. Friction-Free】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eBuilt for outdoor vlogs, live streams, and short videos, LARK A2 offers 3 levels of AI-driven noise cancellation, delivering up to 20 dB of noise cancellation depth for studio-clean dialogue instantly. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【AI Power Saving】\u003c\/strong\u003e\u003cbr\u003eLARK A2 intelligently manages power in the background, continuously adapting to your recording behavior to improve power efficiency by up to 25%[1], so you can stay fully focused on your shooting flow.\"Pocket-Sized. Ready Whenever You Are.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Clip On. Stream Away】\u003c\/strong\u003e\u003cbr\u003eThe LARK A2 transmitter weighs just 8.5g, clipping securely and discreetly onto any outfit. Pre-paired out of the box, it’s ready to use the moment you open the case. Just clip and record.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Instant, Intuitive Control】\u003c\/strong\u003e\u003cbr\u003eLARK A2 keeps key controls instantly accessible—one press for noise cancellation, two for mute, and three for recording—so shooting stays smooth, responsive, and uninterrupted.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Smooth Details. Better Workflow】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e(without camera RX)\u003cbr\u003ePrecise Gain Control\u003cbr\u003eFine-tune your sound with up to 6 levels of gain adjustment via the HollyAudio App, giving you precise control to match every recording scenario.\u003c\/p\u003e\n\u003cp\u003e(with camera RX)\u003cbr\u003ePrecise Gain Control\u003cbr\u003eWith up to 6 levels of gain control via the HollyAudio App on mobile setups and up to 3 levels on camera setups, plus quick adjustment directly on the receiver, LARK A2 adapts your sound naturally to every scenario. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Frictionless Shooting】\u003c\/strong\u003e\u003cbr\u003eFrom independent TX\/RX mute control via onboard buttons to pass-through charging, MFi-certified compatibility, and plug-free playback, every detail is designed to remove friction from your shooting experience.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Pure Audio. Perfectly Tuned】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eCapture every vocal texture.\u003cbr\u003eThe 48kHz \/ 24-bit resolution of LARK A2 preserves the true texture of your voice. It delivers rich, natural audio straight to your vlogs and livestreaming, making every word sound crisp and clear.\u003c\/p\u003e\n\u003cp\u003eWipe out background hiss.\u003cbr\u003eWith a ≥68dB SNR, LARK A2 ensures clean dialogue by automatically wiping out annoying static, electronic hums, and background hiss.\u003c\/p\u003e\n\u003cp\u003eHandles loud voices with clarity.\u003cbr\u003eA high 120dB Max SPL easily handles sudden spikes in volume. Whether you burst into sudden laughter or get excited during a gaming stream, your audio stays smooth and perfectly natural.\u003c\/p\u003e\n\u003cp\u003eAI Voice Tuning\u003cbr\u003eWith a single tap in the HollyAudio App, the AI-powered tuning automatically optimizes your EQ, compression, and de-essing, giving your voice a polished, studio-clean edge in seconds. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Dual Audio Insurance】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eAI Auto-Limit Clip\u003cbr\u003eIntegrating an intelligent auto-level limiter, LARK A2 proactively suppresses sudden volume spikes to eliminate distortion. \u003c\/p\u003e\n\u003cp\u003eSafety Track\u003cbr\u003eLARK A2 can record a secondary backup track at -6dB. This ensures you still get clear, usable audio even in noisy environments. \u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Power That Paces Your Day】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eReady for the All-Day Shoot\u003cbr\u003eThe LARK A2 delivers up to 7 hours of continuous recording per mic, and up to 42 hours of total battery life with the charging case. With AI power saving enabled, battery performance can be further enhanced, extending each mic's runtime up to 9 hours. \u003c\/p\u003e\n\u003cp\u003e5 Mins Charge, 1 Hour Shooting\u003cbr\u003eA quick 5-minute USB-C charge powers the mic for 1 hour of shooting, while the charging case delivers the same 1-hour runtime with just 10 minutes of charging. Stay ready for every unexpected moment.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【200m (650ft) LOS Range】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eThe LARK A2 delivers a rock-solid wireless transmission range of up to 200m (LOS). Enjoy absolute framing freedom and flawless signal stability for all your open-space shoots.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Ready for Any Device】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eFrom smartphones and tablets to computers and action cameras[2], the LARK A2 integrates flawlessly into your setup. Switch devices and formats effortlessly without missing a beat.\u003c\/p\u003e\n\u003cp\u003e[2] Compatibility with action cameras may vary depending on the brand and model.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Voice-Powered Vibe Coding】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eLARK A2 makes Vibe Coding more natural with voice-driven interaction, turning your ideas into AI actions, triggering commands instantly, and supporting multi-agent workflows with greater flexibility.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Hands-Free AI Coding】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eInteract with AI through voice—customize shortcuts in Web Control, trigger commands instantly with one press, and send prompts without relying on your keyboard.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Distance-Free Voice Input】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eLARK captures clear voice input from a distance, so you can interact with AI naturally—even in office environments with quiet, low-volume speech, giving you greater freedom in your workflow.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Multi-Agent Collaboration】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eStay in the flow when working with multiple AI agents. With customizable shortcuts, up to 5 preset templates, and color-coded mic indicators, you can quickly switch between AI workflows, identify each setup, and assign each microphone to a dedicated agent for a more flexible Vibe Coding experience.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e【Keep Coding Without Interruption】\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eUSB-C pass-through charging and adaptive mode switching keep LARK A2 ready for both Vibe Coding and content creation whenever you need it.\u003cbr\u003e\u003c\/p\u003e","brand":"Hollyland Store(AU)","offers":[{"title":"LARK A2 Duo(Space Gray)","offer_id":49234508972251,"sku":null,"price":79.0,"currency_code":"AUD","in_stock":true},{"title":"LARK A2 Mini Duo(Space Gray)","offer_id":49234509005019,"sku":null,"price":70.0,"currency_code":"AUD","in_stock":true},{"title":"LARK A2 Solo (Space Gray)","offer_id":49234509037787,"sku":null,"price":53.0,"currency_code":"AUD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0816\/1368\/4955\/files\/6118-Duo-001.png?v=1788847377","url":"https:\/\/au.hollyland.com\/products\/lark-a2","provider":"Hollyland Store(AU)","version":"1.0","type":"link"}
