- HDMI & SDI connections on both the transmitter and receiver, plus an SDI loopout on the transmitter
- Transmit up to 1000ft LOS range with ultra-low latency down to 40ms
- Embedded UVC for direct 2160x1080/60p HD video feed to computer via USB-C
- Superior anti-interference in the 5.1GHz-5.8GHz frequency
- HDMI & SDI input plus SDI loopout on transmitter, and two SDI outputs and one HDMI output on receiver
- Easy-to-read OLED display showing status and configuration
COSMO C1
$999.00
COSMO C1
$999.00
NOTIFY ME WHEN AVAILABLE
$999.00
Lorem ipsum dolor sit amet consectetur ulputate tempus morbi imperdiet nulla?
Lorem ipsum dolor sit amet consectetur adipiscing elit sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
