- Reinforced audio quality
- Mic boom up/down for easy talk/mute control
- Industry-First Built-In Panel Antenna Solution with Up To 1300ft-radius range
- External FRP antennas included
- Grouping talk mode
- App and website-based system configuration
- 2-wire and 4-wire intercom system interfaces
- 2.5/hr fast charge lithium-Ion battery
With 4 beltpacks
$7,678.00
With 8 beltpacks
$11,198.00
With 4 beltpacks
$7,678.00
NOTIFY ME WHEN AVAILABLE
$7,678.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
