- 1 Transmitter & 4 Receivers (1TX & 1RX in box)
- 1,300ft (400m) LOS Range
- 0.05s Low Latency
- 2.4GHz & 5GHz Dual Band
- Auto Frequency Hopping
- HDMI & SDI
- Multiple Power Supply Options
- UVC & RTMP Streaming
- 4K30 Transmission
- Ready Out of the Box
$790.00
Pyro S-Single Transmitter
$438.00
Pyro S-Single Receiver
$438.00
$790.00
NOTIFY ME WHEN AVAILABLE
$790.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
