Push-to-Talk Wireless Intercom: Beyond the Walkie-Talkie Experience
24-hour Long Duration: Each Headset comes with an Extra Battery-Never Run Out of Power
Active Environment Noise Cancellation
Up to 1100ft (350m) Transmission Range
Full Duplex Communication
Backward Compatible with the First Generation Solidcom C1
Solidcom C1 Pro - 4S
$2,359.00
Solidcom C1 Pro - 4S DH(Double Earmuff)
$2,595.00
Solidcom C1 Pro - 6S
$3,430.00
Solidcom C1 Pro - 8S
$4,628.99
Solidcom C1 Pro Hub8S
$7,918.00
Solidcom C1 Pro Hub Base
$3,195.00
$3,430.00
NOTIFY ME WHEN AVAILABLE
$3,430.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
