$725.00
Add to Wishlist
  • 4K UHD Video Transmission. Mars 4K is the first 4K video transmission system from Hollyland. It enables sharp and detail-rich images for a splendid monitoring experience.
  • 450ft (150m) LOS Range. The transmission distance of Mars 4K is up to 450ft. It's able to cover a scenery of soccer field size.
  • 0.06s Low Latency. Mars 4K transmits 4K video images in real-time with only a 0.06s delay.
  • SDI & HDMI Support. With SDI and HDMI dual interfaces, Mars 4K is a perfect solution for both DSLRs and high-end cinema cameras.
  • Broadcast & Production Frame Rate. Mars 4K supports decimal-point frame rates to facilitate professional video production at the broadcasting level.
  • Flexible Monitoring Options. Mars 4K allows connection with RXs or mobiles/Tablets. It's able to connect with 2 receivers simultaneously. When connected to one receiver only, the transmitter can connect two phones/tablets via the Hollyview app. If no receivers are connected, Mars 4K transmitter can connect 4 mobile devices in total.
  • Smart Channel Scan & Selection. Stable connection and reliable transmission are available upon startup.  Mars 4K will scan available channels and auto-select the most robust one to build a connection.
  • Multiple Power Supply Options. Mars 4K can be powered up via multiple options, including NP-F batteries, DC Adapter of 6V to 16V, and Type-C charger of 5V 2.5A.
Mars 4K Kit
Mars 4K Kit
$725.00
$725.00
