- 1TX & 4RX (1 Monitor in box)
- 1300ft (400m) & 0.06s Latency
- 2.4 GHz & 5 GHz Dual Band
- Auto Frequency Hopping
- TX, RX, and Monitor – All in One
- Dual-View Quick Monitoring Switch
- 7-Inch & 1500 nits
- Precise Image Analysis
- SDI & HDMI Loopout
- RTMP Streaming
$1,054.00
Pyro 7 Dual Kit
$1,758.00
Pyro 7 & Pyro S Bundle
$1,846.00
$1,054.00
NOTIFY ME WHEN AVAILABLE
$1,054.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
