- Transmitter weighs only 7g, lightest wireless microphone in the industry
- 48 kHz / 24-bit Sample Rate and Depth, High-Fidelity Audio
- 300m (1000ft) Range, Superior Anti-interference
- Powerful Noise Cancellation, Always Stay Clear
- Discreet Hidden Mic Design
- 30 Hours Battery Life
- Easy to Use and Universally Compatible
LARK M2S Ultimate Combo (Space Gray)
$195.00 $227.75
$195.00 $227.75
NOTIFY ME WHEN AVAILABLE
$195.00
$227.75
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
