2TX & 1RX Solution
3,000ft (1,000m) LOS Range & 33ms Ultra-Low Latency
Seamless Frequency Hopping Technology with HEVO 2.0
NDI HX3 & HDMI & SDI Ports Support
UVC & RTMP Streaming & Multi-Platform Support
FPS Booster
Fractional Frame Rate
Versatile Power Options
Customizable Frozen Frame
Cosmo C2-1 Transmitter and 1 Receiver Kit
$1,758.00
Cosmo C2-2 Transmitters and 1 Receiver Kit
$2,286.00
Cosmo C2-Wireless Video Transmitter
$702.00
$2,286.00
NOTIFY ME WHEN AVAILABLE
$2,286.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
