Hollyland Astra P1 UHD 4K NDI PTZ Camera with 30x Optical Zoom
The Hollyland Astra P1 is a professional-grade PTZ camera designed for live production, houses of worship, education, corporate events, sports coverage, and conference environments. Featuring a UHD 4K imaging system, powerful 30x optical zoom, AI-powered auto tracking, and NDI®|HX3 support, the Astra P1 delivers high-quality video and intelligent operation for demanding production workflows.
Equipped with face-detection auto exposure and advanced AI tracking technology, the camera automatically keeps presenters and performers perfectly framed, reducing the need for manual camera operation. With flexible connectivity including HDMI, 3G-SDI, USB, and IP streaming, the Astra P1 easily integrates into modern production and streaming systems.
Key Features
- UHD 4K60 video output
- Powerful 30x optical zoom lens
- AI Auto Tracking technology
- Face Detection Auto Exposure (AE)
- NDI®|HX3 support for IP production workflows
- HDMI, 3G-SDI, USB and Ethernet outputs
- Supports H.264, H.265 and MJPEG encoding
- PTZ control via RS232, RS485 and IP
- Up to 255 preset camera positions
- Optional PTZ controller support
- PoE+ capable for simplified installation
- Backed by a 5-Year Warranty
Imaging System
- Sensor: 1/1.8" High-Quality CMOS
- Effective Resolution: 8.42MP (16:9)
- Optical Zoom: 30x (7.1mm – 210mm)
- Digital Zoom: 16x
- Aperture Range: f/1.6 – f/5.19
- Minimum Illumination: 0.5 Lux
- Signal-to-Noise Ratio: ≥55dB
Video Output Formats
HDMI
- 2160p up to 60fps
- 1080p up to 60fps
- 1080i up to 60fps
- 720p up to 60fps
3G-SDI
- 1080p up to 60fps
- 1080i up to 60fps
- 720p up to 60fps
PTZ Performance
- Pan Range: ±170°
- Tilt Range: -30° to +90°
- Pan Speed: 1.7°/s to 100°/s
- Tilt Speed: 1.7°/s to 69.9°/s
- Presets: 255 positions
- Preset Accuracy: 0.1°
Connectivity
Video Interfaces
- 1 × HDMI 2.0
- 1 × 3G-SDI
- 1 × USB 3.0 Type-B
- 1 × USB 2.0 Type-A
Audio Interfaces
- 1 × 3.5mm Line In
- 1 × 3.5mm Line Out
Control Interfaces
- RS485 (2-pin Phoenix Terminal)
- RS232 (8-pin Mini-DIN)
Network
- RJ45 Gigabit Ethernet (10/100/1000 Mbps)
Streaming & Network Features
- Video Compression: H.264 / H.265 / MJPEG
- Main Stream Resolution:
- Up to 3840 × 2160
- Sub Stream Resolution:
- Up to 720 × 480
- Supported Protocols:
- NDI®|HX3
- RTSP
- RTMP
- SRT
- HTTP
- TCP/IP
- Multicast
- DVR and more
Physical Specifications
- Power Input: DC 12V / PoE+
- Power Consumption: 18W (Max)
- Operating Temperature: 0°C to 40°C
- Storage Temperature: -40°C to 60°C
- Dimensions: 169 × 188 × 226mm
- Weight: Approx. 2.3kg
Ideal Applications
- Houses of Worship
- Live Events
- Corporate Presentations
- Education & Lecture Capture
- Conference Rooms
- Sports Production
- Broadcast Studios
- Hybrid & Online Streaming
What's in the box:
1 x Hollyland Astra-P1 PTZ Camera (NDI Activated)
1 x Remote Controller
1 x Power Adapter
1 x USB-B to USB-A Cable
1 x RS232 Cable
1 x Wall Mount Bracket
1 x Ceiling Mount Bracket
