Hollyland Cosmo C2 HDMI/SDI Wireless Video Transmission System
Features
- Wireless Video Transmitter/Receiver Set
- Transmitter: HDMI/SDI In, SDI Loop Out
- Receiver: 2 HDMI/SDI Outputs
- 1000m Line-of-Sight 1080p60 Transmission
- 5.1 to 5.85 GHz Frequency Bands
- Supports UVC, RTMP & NDI|HX Streaming
- FPS Booster Converts Frame Rates
- HEVO 2.0 Technology, 33 ms Latency
- DC Input, L-Series Battery Plate and V mount on RX.
The Hollyland Cosmo C2 HDMI/SDI Wireless Video Transmission System enables seamless, long-range 1080p60 video transmission up to 1000m to a single receiver, providing flexible monitoring and distribution for both studio and field productions. Operating within the 5.1 to 5.85 GHz wireless frequency range, this kit includes a transmitter and receiver for reliable, high-quality signal transmission. Enhancements to the series include HEVO 2.0 technology, support for UVC, RTMP, and NDI|HX streaming, and expanded power options for greater versatility.
Strong Signal Strength, Seamless Frequency Hopping
The Cosmo C2 can transmit 1080p60 video up to 1000m line-of-sight with a low 33 ms latency. The system operates on the 5 GHz frequency band, automatically detecting surrounding frequency interference and seamlessly switching to a clean channel via HEVO 2.0 technology. This makes for an uninterrupted transmission signal.
Connectivity
- The transmitter features one HDMI input, one SDI input, and one SDI loop output.
- The receiver features two HDMI outputs, two SDI outputs, and an RJ45 Ethernet port.
- USB-C ports on both units allow you to connect to the included USB-C OTG adapter and your personal computer for UVC streaming.
RTMP and NDI|HX Streaming
The Cosmo C2 unlocks RTMP streaming for direct live streaming to YouTube, Twitch, and other platforms. The receiver unit supports NDI|HX protocol, transmitting video streams via a single network cable for a cleaner production space.
FPS Booster, Fractional Frame Rate
Using a frame rate compensation algorithm, the Cosmo C2 receiver can convert low frame rate inputs like 1080p24/25/30 to high frame rate outputs at 1080p60, making smoother visuals. The Cosmo C2 can also transmit HDMI/SDI fractional frame rate input/output signals to ensure flexibility while filming.
Frozen Frame
If your transmission is interrupted, Cosmo C2 can freeze the last frame of your feed, effectively preventing the display of the manufacturer's logo. There is also the option to customize the logo image if you prefer to use a USB flash drive for a more professional appearance.
Versatile Power and Mounting Options
Each unit can be powered via DC input using the included power supply when working on set. In field applications or in studio spaces with limited outlets, both units offer battery plate options. The transmitter features an L-series battery plate, and the receiver features a V-mount battery plate for higher-capacity power sources. Use the 1/4"-20 threads on the units or the cold shoe adapter to secure them to the mounting configurations of your choice.
| Video I/O | Transmitter: 1x HDMI 1.4b Input |
| Embedded Audio | HDMI/SDI |
| Latency | 33 ms |
| Video Format | HDMI/SDI |
| Battery Type | Transmitter: 1x L-Series |
| Power Consumption | Transmitter: 10 W |
| Mounting | Transmitter/Receiver: 1/4"-20 Female (Bottom) |
Inputs/Outputs
| Antenna I/O | Transmitter/Receiver: 2x RP-SMA |
| Audio I/O | No |
| Power I/O | Transmitter/Receiver: 1x Barrel Input |
| Other I/O | Transmitter/Receiver: 1x USB-C |
| Encryption | No, |
Wireless
| Wireless Range | 3000' / 914.4 m |
| Channel Bandwidth | 40 MHz |
| Frequency Range | 5.1 to 5.85 GHz |
| Latency | 33 ms |
| RF Power | < 23 dBm |
| RF Sensitivity | -90 dBm |
| Wi-Fi | Yes |
| Bluetooth | No |
| Mobile App Compatible | No |
| Cellular Support | No |
Format Support
| Audio Format | Not Specified by Manufacturer |
| Timecode Support | No |
Power
| Input Power | 6 to 16 VDC |
Mounting
General
| Status Display | Receiver: LCD |
| Environmental Resistance | No |
| Dimensions | Transmitter: 114.8 x 69 x 35.5 mm |
| Weight | Transmitter: 210.00 g |
What's in the box:
1 x Hollyland Cosmo C2 Receiver
1 x Hollyland Cosmo C2 Transmitter
1 x USB-C OTG Adaptor
1 x Cold Shoe Mount
1 x Power Adaptor (Australia Standard)
1 x Hard Shell Carry Case
