Hollyland LARK M2 Wireless Camera-Mount Receiver for LARK M2 Systems (2.4 GHz, Shine Charcoal)
Items Included
- Hollyland LARK M2 Wireless Camera-Mount Receiver for LARK M2 Systems (2.4 GHz, Shine Charcoal)
- USB-A to USB-C Cable
- 3.5mm TRS to TRS Cable
- Limited 1-Year Manufacturer Warranty
Key Features
- For Hollyland LARK M2 Wireless Systems
- Camera-Mount Dual-Channel Receiver Unit
- Onboard Controls, Volume Dial
- 3.5mm TRS Output, USB-C Port
- 1000' Transmission Distance
- 145mAh Battery, 9-Hour Runtime
Hollyland LARK M2 Specs
Key Specs
| Wireless Technology | Digital 2.4 GHz |
| Diversity | Non-Diversity |
| Max Operating Range | 1000' / 304.8 m |
| Receiver Type | 1x Camera-Mount |
| Number of Audio Channels | 2 |
| Included Transmitters | No Transmitters Included |
| Microphone Type | No Microphone Included |
| Included Charging Case | No |
System
| RF Frequency Band | 2400 MHz |
| Max Transmitters per Band | 2 |
| Encryption | No |
| Built-In Recorder | No |
| Timecode Support | No |
| Mobile App Compatible | Yes: Android & iOS |
Receiver
| Mounting Options | Shoe-Mount (with Included Hardware) |
| Antenna | 1x Internal |
| Audio I/O | 1x 1/8" / 3.5 mm TRS Unbalanced Output |
| Network I/O | No |
| USB/Lightning Connectivity | 1x USB-C Female |
| Frequency Response | 20 Hz to 20 kHz |
| Display | Single-LED Indicators Only |
| Power Requirements | Battery |
Transmitters
Microphones
Power
| Receiver Battery Type | 1x Built-In Rechargeable - 145 mAh |
| Receiver Battery Life | 9 Hours |
| Battery Charging Time | 1.5 Hours |
Physical
| Environmental Resistance | No |
| Dimensions | 1.6 x 1.1 x 0.8" / 40 x 27.5 x 20.5 mm |
| Weight | 0.5 oz / 14.8 g |
