Hollyland LARK M2 Wireless Microphone Transmitter for LARK M2 Systems (2.4 GHz, Shine Charcoal)
Key Features
- For Hollyland LARK M2 Wireless Systems
- Transmitter with Built-In Omni Mic
- Environmental Noise Cancellation
- Remote Video Recording Control
- 97mAh Battery, 10-Hour Runtime
- Includes Furry Windscreen, Sticker Sheet
Hollyland LARK M2 Specs
Key Specs
| Wireless Technology | Digital 2.4 GHz |
| Max Operating Range | 1000' / 304.8 m (with Obstruction) |
| Included Transmitters | 1x Clip-On |
| Microphone Type | 1x Built-In (Clip-On Transmitter) |
| Included Charging Case | No |
System
| RF Frequency Band | 2400 MHz |
| RF Channel Scanning | Auto-Scan |
| Max Transmitters per Band | 2 |
| Encryption | No |
| Built-In Recorder | No |
| Timecode Support | No |
| Mobile App Compatible | Yes: Android & iOS |
Transmitters
| Antenna | Internal |
| Input Level | Microphone |
| Audio I/O | No |
| USB I/O | No |
| Muting | No |
| Auto-Level/Gain | Yes |
| Frequency Response | 20 Hz to 20 kHz |
| Sync Method | 2.4 GHz QPSK |
| Display | Single-LED Indicators Only |
Microphones
| Polar Pattern | Omnidirectional |
| Maximum SPL | 115 dB |
| Sensitivity | -34 dBV/Pa (at 1 kHz) |
| Color | Black |
Power
| Transmitter Battery Type | 1x Built-In Rechargeable - 97 mAh |
| Transmitter Battery Life | 10 Hours |
| Battery Charging Time | 1.5 Hours |
| AC/DC Power Adapter | No |
Physical
| Environmental Resistance | No |
| Dimensions | 1 x 0.4" / 26 x 9.9 mm |
| Weight | 0.3 oz / 9 g |
