Hollyland LARK M2S DUO 2-Person Wireless Microphone System with USB-C Connector for Mobile Devices (2.4 GHz, Space Gray)
$159.00
Add to Wishlist
Features
  • For Mobile Journalism, Content Creation
  • 2 x Ultracompact Transmitters with Mics
  • USB-C Plug-In Receiver
  • Up to 1000' Transmission Distance
  • 48 kHz, 24-Bit Audio Sampling
  • Environmental Noise Cancellation
  • LED Indicators, Built-In Batteries
  • iOS/Android App Control
  • Included Charging Case
Record up to two people in mobile journalism or content creation applications using this LARK M2S DUO Wireless Microphone System from Hollyland. The system includes two ultracompact transmitters with built-in omnidirectional microphones for discreet recording, a USB-C plug-in receiver for direct connection with mobile devices, and a charging case. The transmitters feature a titanium clip-on design to attach securely to your talent and do not have visible logos for a low-profile appearance.
Stable Audio Transmission
The LARK M2S transmitters are engineered with RF interference-resistant circuits for pristine sound quality in most environments. Audio is transmitted via 2.4 GHz frequency up to 1000' away. Easily capture 24-bit, 48 kHz audio with a 70 dB signal-to-noise ratio and 116 dB SPL. Toggle environmental noise cancellation using the transmitters' onboard controls for clear audio capture in loud spaces. Included windscreens improve audio quality outdoors.
Plug-In Receiver
The USB-C plug-in receiver is compatible with iOS and Android devices. It runs on plug-in power from your connected device and features LED indicators to show the mode status of each transmitter unit.
LarkSound App
Connect your LARK M2S system to the LarkSound App to adjust parameters like volume and noise cancellation, update firmware, or check real-time audio status-all from your iOS or Android compatible smartphone. Your smartphone can also playback your recordings when connected to the receiver without needing to unplug it.
Long Battery Life, Charging Case
  • The transmitters feature 85mAh internal batteries with 9-hour battery life. Once depleted, recharge the components in the included charging case in less than 1.5 hours or via USB-C in 1 hour.
  • The charging case is specifically designed to accommodate the plug-in receiver and two transmitter units. Its 680mAh internal battery can recharge the entire system multiple times for a total battery life of 30 hours.
What's in the box:
2 x Hollyland Lark M2S Micrephone
1 x Hollyland Lark M2S USB-C Plug for the Phone
1 x Hollyland LArk M2S Charging Case
2 x WindScreen
1 x USB Cable (USB-A to USB-C)
$159.00
$159.00
