Hollyland Lark M2S Ultimate Combo Kit for Camera, Android and Apple IOS
Features
- Titanium Clip Innovative Design
- 48 kHz / 24-bit High Fidelity
- Environmental Noise Cancellation
- 30-Hour Battery Life
- 300m (1000ft) Wireless Range
- App Control (Plug & Play)
- Universal Compatibility (Combo Version)
Specifications:
| Product Name | LARK M2S |
| Audio Receiver Interface |
| Wireless Technology | 2.4GHz AFH |
| LOS Range | 300m (1,000ft) |
| Mic Polar Pattern | Omnidirectional |
| Frequency Range | 20 Hz - 20 kHz |
| Sampling Rate / Bit Depth | 48 kHz / 24-bit |
| Maximum SPL | 116dB SPL |
| Default Dynamic Range | 80dB (Mobile Version) 94dB (Camera Version) |
| Battery Capacity | TX: 85 mAh; Camera Version RX: 145 mAh; Mobile Version Charging Case: 680 mAh Combo Version Charging Case: 1300 mAh |
| Noise Cancellation | Y (ENC) |
| Internal Recording | N |
| USB Digital Audio Output | Y |
| Analog Input | N/A |
| Analog Output | N/A |
| Mono Mode | Y |
| Stereo Mode | Y |
| Safety Track | N |
| EQ Settings | N |
| Mic Gain Settings | Y |
| MFi-Certification | Y |
| App Support | Y |
| Display Screen | N |
| Indicator/Screen Brightness Adjustment | N |
| Real-Time Monitoring | N |
| Magnetic Attachment | N |
| Wired Lavalier Mic Connection | N |
| Operating Time (Approx.) | TX: Approx. 9 hours Camera Version RX: Approx. 8.5 hours Mobile Version Charging Case: > 2 times charging for 2 TX at the same time Combo Version Charging Case: > 2.5 times charging for all TX and RX at the same time |
| Charging Time (Approx.) | TX: Approx. 1 hour Camera Version RX: Approx. 1 hour Mobile Version Charging Case: < 1.5 hours Combo Version Charging Case: < 1.5 hours |
