Hollyland LARK M2S Wireless Microphone Transmitter for LARK M2S Systems (2.4 GHz, Shine Charcoal)
1 / 3
$75.00
Add to Wishlist
Key Features
  • For Hollyland LARK M2S Wireless Systems
  • Ultracompact Transmitter with Omni Mic
  • Environmental Noise Cancellation
  • 1000' Transmission Distance
  • 85mAh Battery, 9-Hour Runtime
  • Includes Windscreen, Charging Cable
Hollyland HL-LARK M2S TRANSMITTER Specs
Key Specs
Wireless Technology
Digital 2.4 GHz
Diversity
Non-Diversity
Max Operating Range
1000' / 304.8 m (Line of Sight)
Included Transmitters
1x Clip-On with Microphone
Microphone Type
1x Built-In (Clip-On Transmitter)
Included Charging Case
No
System
Wireless Technology
Digital 2.4 GHz
Diversity
Non-Diversity
RF Frequency Band
2400 MHz
RF Channel Scanning
Auto-Scan
Max Operating Range
Max Transmitters per Band
2
Built-In Recorder
No
Timecode Support
No
Mobile App Compatible
Yes: Android & iOS
App Name: LarkSound
Transmitters
Antenna
Internal
Input Level
Microphone
Audio I/O
No
Bias/Plug-In & Phantom Power
No Bias/Plug-In Power
No Phantom Support
USB I/O
No
Muting
Off/On Switch
Auto-Level/Gain
Yes
Frequency Response
20 Hz to 20 kHz
Sync Method
2.4 GHz QPSK
Display
Single-LED Indicators Only
Microphones
Microphone Type
Polar Pattern
Omnidirectional
Frequency Response
20 Hz to 20 kHz
Maximum SPL
116 dB
Sensitivity
-37 dBV
Color
Gray
Power
Transmitter Battery Type
1x Built-In Rechargeable (Not Replaceable)
Transmitter Battery Life
9 Hours
Battery Charging Time
1 Hour
No
AC/DC Power Adapter
No
Physical
Environmental Resistance
No
Housing
Metal
Dimensions
0.5 x 0.2" / 13 x 6.3 mm
0.9 x 0.4" / 24 x 9 mm
Weight
0.2 oz / 7 g
$75.00
$75.00
