Hollyland LARK MAX 2 Clip-On Wireless Microphone Transmitter (Space Gray, 2.4 GHz)
The LARK MAX 2 transmitter/microphone is designed with both form and function in mind. Its sleek, low-profile body allows for discreet, versatile placement using the included hidden magnetic clip—perfect for on-camera talent or fast-paced productions. A furry windshield and a convenient charging dock are also included to ensure optimal audio performance and maximum convenience.
32-Bit Float Recording with Timecode Sync
Capture every detail with confidence. The LARK MAX 2 features a built-in recorder that utilizes 32-bit float technology, delivering pristine audio with an exceptionally wide dynamic range. This advanced format virtually eliminates digital clipping and allows low-volume recordings to be safely amplified without introducing noise—ensuring clean, professional results every time.
With 8GB of internal storage, the transmitter can record up to 14 hours of uncompressed, high-resolution audio, making it a dependable backup solution in any shooting environment. Even when wireless transmission is disrupted or unavailable, the LARK MAX 2 functions as a standalone recorder, ideal for remote shoots, events, and high-stakes interviews.
An integrated, frame-accurate timecode system allows for seamless syncing between recorded audio and video footage, eliminating the need for manual alignment in post-production and streamlining your workflow from shoot to edit.
Featherlight Comfort Meets Modern Style
Weighing just 0.5 oz (14 g) and measuring a mere 0.4 inches thin, the LARK MAX 2 is built to blend effortlessly into any outfit. Its ultra-slim profile won’t tug on fabric or disrupt your appearance, making it ideal for interviews, podcasts, vlogging, and more.
The innovative hover-clip mechanism replaces bulky spring clips with a secure, magnetic push-and-pull design—enabling fast, precise placement with minimal effort. Whether mounted on a lapel, collar, or hidden under clothing, the LARK MAX 2 stays comfortably in place.
Engineered for long-wear sessions, the transmitter features a skin-friendly, excimer nano-coated finish, offering a smooth and soft touch against the skin—perfect for extended shoots or live events.
Intuitive One-Touch Control
Take control with a tap. The LARK MAX 2 keeps essential functions right at your fingertips:
On/Off Button:
Single press: Activates noise cancellation
Double press: Mutes the microphone
REC Button:
Single press: Starts onboard recording
Simple, responsive, and built for creators on the move, the LARK MAX 2 ensures you're always ready to capture the moment—clearly, cleanly, and effortlessly.
What's included:
1 x Transmitter
1 x Furry Windfield
1 x USB-C to USB-C Cable
1 x USB-C to 3.5mm Adapter
1 x Magnetic Silicone Sleeve
1 x Magnet
