Hollyland Solidcom C1 Pro Roaming Hub 10S Full-Duplex Wireless Intercom System
1 / 8
$16,175.00
Add to Wishlist
Features
  • Communication for Mobile Production Team
  • Two-Mic Environmental Noise Cancellation
  • Reliable 1.9 GHz DECT 6.0 Technology
  • Hub with V-Mount for Seamless Roaming
  • 10 Single-Ear Headsets, Expandable to 20
  • Wide Frequency Response for Clear Audio
  • 500m 2-Way Operating Range, App Control
  • Mute/PTT Button or Rotate Boom to Mute
  • Includes Headset Batteries & Charger
  • Backward Compatible with Solidcom C1
Designed for mobile production teams and featuring dual-mic Environmental Noise Cancellation (ENC) for use in loud environments, the Hollyland Solidcom C1 Pro Roaming Hub 10S is a full-duplex wireless DECT intercom system with hub engineered to provide clear audio and all-day wearing comfort in a true-wireless design with no bodypack required. This configuration includes 10 single-ear headsets, along with 20 rechargeable batteries, an 8-bay charging station, and accessories.
The system transmits in the 1.9 GHz spectrum and uses proven DECT 6.0 technology to ensure secure and reliable transmission at a line-of-sight range of up to 500m—making it well suited for a variety of applications, including film/TV production, concerts, and live events.
Roaming Hub with V-Mount and 6 Groups
  • This version of the Solidcom C1 Pro Roaming Hub features a V-mount for use with compatible external batteries, allowing you to take the system anywhere the action leads.
  • The hub provides more communication options with up to 6 groups available, greatly eliminating the possibility of communication interruption and improving team coordination efficiency.
10 True-Wireless Single-Ear Headsets for 2-Way Communication
  • The single-ear headset design is dust and water resistant and designed to provide a comfortable all-day wearing experience.
  • Using the Roaming Hub conveniently eliminates the need for a specific master headset.
  • For clear communication in loud environments, engage the dual-mic ENC (Environmental Noise Cancellation) feature.
  • The ENC algorithm combines the main directional microphone at the speaker's mouth with a secondary omnidirectional environmental mic on the earcup to cancel out unwanted background noise for more intelligible speech.
  • The microphone's wide 150 Hz to 7 kHz frequency response ensures detailed voice capture to keep your team working efficiently.
UAC for Cloud Meetings
  • The USB Audio Class (UAC) function featured on the hub facilitates joining cloud meetings anytime running on Zoom, Skype, or other meeting programs.
  • Simply connect your personal computer to the hub via its USB interface. This seamlessly brings your on-site and remote teams together, facilitating team interaction and creativity wherever your teams are located.
Rechargeable Batteries + Charging Station
  • Each headset runs on a single rechargeable battery
  • Each remote headset will last for up to 10 hours on a single battery charge with the ENC engaged
  • Each battery fully recharges in 2.5 hours
  • An 8-bay battery charging station and AC adapter are included.
Expandable and Backwards Compatible
  • The Solidcom C1 Pro Roaming Hub system allows you to link up to 20 headsets.
  • The C1 Pro Roaming Hub is backward-compatible with the Solidcom C1 system.
  • You can easily daisy-chain different systems as needed on site to meet even more complex operational requirements.
Users per System
10
Wireless Technology
Digital DECT (1.9 GHz)
Operating Range
500m
Encryption
Proprietary
Inputs/Outputs
2x RJ45
1x USB-A
1x USB-C
Earpiece Design
On-Ear (Supra-Aural) / Over-Ear (Circumaural)
Number of Earpieces
Single Earpiece (Left or Right Side)
System
Number of Included Headsets
10x Single-Sided Headset
Users per System
10
Wireless Connectivity
Wireless Technology
DECT Standard
6.0
Operating Range
500m
RF Bandwidth
1.73 MHz
Max Transceivers per Band
20
Wireless Modulation
Analog: GFSK
Duplex Mode
Full-Duplex (FDX)
Approximate RF Sensitivity
-90 dBm
Frequency
1920 to 1930 MHz
Encryption
Proprietary
Mobile App Compatible
Yes: Android & iOS
Base Station
Inputs/Outputs
2x RJ45
1x USB-A
1x USB-C
Antenna
Base Station:
4x External, Detachable
AC/DC Power Adapter
12 VDC (Included)
Headphone
Earpiece Design
Earpiece Connection / Wearing Style
Headband
Number of Earpieces
Sound Field
Mono
Controls/Microphone Location
Controls: Adjustable Boom, Earpiece (Side Unspecified)
Microphone: Earpiece (Side Unspecified)
Frequency Response
150 Hz to 7 kHz
Total Harmonic Distortion (THD)
1%
Maximum Sound Pressure Level (SPL)
115 dB
SNR
Headphones:
>71 dB
Microphone
Microphone Type
Electret Condenser
Mic Boom Location
Interchangeable (Left or Right Side)
Pickup Pattern
Cardioid (Unidirectional)
Noise Cancelling Microphone
Yes
Maximum SPL
115 dB
Distortion
<1%
Wired Connectivity
Audio Connector
No
Audio Connector to Earpiece
No Wired Audio Support
Battery
Battery Type
Headset:
1 x 26650
Battery Chemistry
Headset:
Lithium-Ion
Capacity (mAh)
700 mAh
Runtime
Headset:
10 Hours
Recharge Time
2.5 Hours
Environmental
Operating Temperature
-10 to 45°C
Storage Temperature
-20 to 60°C
Content list:
1 x Hollyland Solidcom C1 Pro Roaming Hub
10 x Hollyland Solidcom C1 Pro Single Ear Headset (ENC and NFC on borad)
20 x Hollyland Solidcom C1 Pro Battery
1 x Hollyland Solidcom C1 Pro 8 Slot Battery Charger
4 x Hollyland Solidcom C1 Pro Roaming Hub Antenna
10 x Hollyland Solidcom C1 Pro Over-Ear Earmuff
10 x Hollyland Solidcom C1 Pro On-Ear Earmuff
10 x Hollyland Solidcom C1 Pro Earpad
10 x Mic Cushion
1 x Hardshell Carry Case
$16,175.00
$16,175.00
