Hollyland Solidcom C1 Pro Roaming Hub 20S Full-Duplex Wireless Intercom System
Features
- Communication for Mobile Production Team
- Two-Mic Environmental Noise Cancellation
- Reliable 1.9 GHz DECT 6.0 Technology
- Hub with V-Mount for Seamless Roaming
- 20 Single-Ear Headsets, Expandable to 20
- Wide Frequency Response for Clear Audio
- 500m 2-Way Operating Range, App Control
- Mute/PTT Button or Rotate Boom to Mute
- Includes Headset Batteries & Charger
- Backward Compatible with Solidcom C1
Designed for mobile production teams and featuring dual-mic Environmental Noise Cancellation (ENC) for use in loud environments, the Hollyland Solidcom C1 Pro Roaming Hub 20S is a full-duplex wireless DECT intercom system with hub engineered to provide clear audio and all-day wearing comfort in a true-wireless design with no bodypack required. This configuration includes 20 single-ear headsets, along with 40 rechargeable batteries, an 8-bay charging station, and accessories.
The system transmits in the 1.9 GHz spectrum and uses proven DECT 6.0 technology to ensure secure and reliable transmission at a line-of-sight range of up to 500m—making it well suited for a variety of applications, including film/TV production, concerts, and live events.
Roaming Hub with V-Mount and 6 Groups
- This version of the Solidcom C1 Pro Roaming Hub features a V-mount for use with compatible external batteries, allowing you to take the system anywhere the action leads.
- The hub provides more communication options with up to 6 groups available, greatly eliminating the possibility of communication interruption and improving team coordination efficiency.
20 True-Wireless Single-Ear Headsets for 2-Way Communication
- The single-ear headset design is dust and water resistant and designed to provide a comfortable all-day wearing experience.
- Using the Roaming Hub conveniently eliminates the need for a specific master headset.
- For clear communication in loud environments, engage the dual-mic ENC (Environmental Noise Cancellation) feature.
- The ENC algorithm combines the main directional microphone at the speaker's mouth with a secondary omnidirectional environmental mic on the earcup to cancel out unwanted background noise for more intelligible speech.
- The microphone's wide 150 Hz to 7 kHz frequency response ensures detailed voice capture to keep your team working efficiently.
UAC for Cloud Meetings
- The USB Audio Class (UAC) function featured on the hub facilitates joining cloud meetings anytime running on Zoom, Skype, or other meeting programs.
- Simply connect your personal computer to the hub via its USB interface. This seamlessly brings your on-site and remote teams together, facilitating team interaction and creativity wherever your teams are located.
Rechargeable Batteries + Charging Station
- Each headset runs on a single rechargeable battery
- Each remote headset will last for up to 10 hours on a single battery charge with the ENC engaged
- Each battery fully recharges in 2.5 hours
- Three 8-bay battery charging stations and AC adapter are included.
Expandable and Backwards Compatible
- The Solidcom C1 Pro Roaming Hub system allows you to link up to 20 headsets.
- The C1 Pro Roaming Hub is backward-compatible with the Solidcom C1 system.
- You can easily daisy-chain different systems as needed on site to meet even more complex operational requirements.
| Users per System: | 20 |
| Wireless Technology: | Digital DECT (1.9 GHz) |
| Operating Range: | 500m |
| Encryption: | Proprietary |
| Inputs/Outputs: | 2x RJ45 |
| Earpiece Design: | On-Ear (Supra-Aural) / Over-Ear (Circumaural) |
| Number of Earpieces | Single Earpiece (Left or Right Side) |
System
| Number of Included Headsets: | 20x Single-Sided Headset |
| Users per System | 20 |
Wireless Connectivity
| Wireless Technology | Digital DECT (1.9 GHz) |
| DECT Standard | 6.0 |
| Operating Range | 500m |
| RF Bandwidth | 1.73 MHz |
| Max Transceivers per Band | 20 |
| Wireless Modulation | Analog: GFSK |
| Duplex Mode | Full-Duplex (FDX) |
| Approximate RF Sensitivity | -90 dBm |
| Frequency | 1920 to 1930 MHz |
| Encryption | Proprietary |
| Mobile App Compatible | Yes: Android & iOS |
Base Station
| Inputs/Outputs | 2x RJ45 |
| Antenna | Base Station: |
| AC/DC Power Adapter | 12 VDC (Included) |
Headphone
| Earpiece Design | On-Ear (Supra-Aural) / Over-Ear (Circumaural) |
| Earpiece Connection / Wearing Style | Headband |
| Sound Field | Mono |
| Controls/Microphone Location | Controls: Adjustable Boom, Earpiece (Side Unspecified) |
| Frequency Response | 150 Hz to 7 kHz |
| Total Harmonic Distortion (THD) | 1% |
| Maximum Sound Pressure Level (SPL) | 115 dB |
| SNR | Headphones: |
Microphone
| Microphone Type | Electret Condenser |
| Mic Boom Location | Interchangeable (Left or Right Side) |
| Pickup Pattern | Cardioid (Unidirectional) |
| Noise Cancelling Microphone | Yes |
| Maximum SPL | 115 dB |
| Distortion | <1% |
Wired Connectivity
| Audio Connector | No |
| Audio Connector to Earpiece | No Wired Audio Support |
Battery
| Battery Type | Headset: 1 x 26650 |
| Battery Chemistry | Headset:Lithium-Ion |
| Capacity (mAh) | 700 mAh |
| Runtime | Headset:10 Hours |
| Recharge Time | 2.5 Hours |
Environmental
| Operating Temperature | -10 to 45°C |
| Storage Temperature | -20 to 60°C |
Content list:
1 x Hollyland Solidcom C1 Pro Roaming Hub
20 x Hollyland Solidcom C1 Pro Single Ear Headset (ENC and NFC on borad)
40 x Hollyland Solidcom C1 Pro Battery
3 x Hollyland Solidcom C1 Pro 8 Slot Battery Charger
4 x Hollyland Solidcom C1 Pro Roaming Hub Antenna
20 x Hollyland Solidcom C1 Pro Over-Ear Earmuff
20 x Hollyland Solidcom C1 Pro On-Ear Earmuff
20 x Hollyland Solidcom C1 Pro Earpad
20 x Mic Cushion
1 x Hardshell Carry Case
