Hollyland Solidcom C1 Pro Wireless Intercom System Hub Base Only
Hub Base for Hollyland Solidcom C1 Pro System.
Features
- HUB Base Only without Headsets
- Use with 8 True-Wireless Remote Headsets
- Wide Frequency Response for Clear Audio
- 1000' 2-Way Operating Range
- DECT 6.0 for Stability and Security
- Acoustic Echo Cancellation
- A/B Grouping, Announce Key
- Flexible Powering Options
- Cascade Additional HUBs to Expand System
Expand your intercom system's capabilities with the Hollyland Solidcom C1 Pro HUB Base. While the Solidcom C1 Pro system allows you to operate up to 8 headsets without a HUB, adding the HUB allows you to use 8 remote headsets at the same time (headsets available separately). The complete system uses DECT 6.0 encryption and dual-antenna technology to ensure secure and reliable transmission at a range of up to 1000'—making it well suited for a variety of applications, including film production, concerts, and public events.
In addition to expanding the number of usable headsets, the HUB also offers A/B grouping and an Announce key for emergencies. The system can be expanded with additional HUB units and headsets (available separately) to accommodate up to 24 remote headsets.
Wide Frequency Response for Precise Coordination
The Solidcom C1 system offers a 150 Hz to 7 kHz frequency response and premium acoustic echo cancellation (AEC) to ensure clear intelligible audio for effective teamwork.
Enhanced Stability and Security with DECT 6.0
Built on the powerful DECT 6.0 platform and featuring a dual-antenna diversity scheme, the Solidcom C1 can prevent people outside the system from hearing your conversation with encryption technology and provides stable and reliable transmission with doubled user capacity on the communication channel.
HUB Base with Additional Features
The HUB offers additional features including A/B grouping and an Announce key that mutes all the headsets for emergency messages from the HUB base. The featured UAC (USB Audio Class) function enables the HUB to join in any cloud meeting running on Zoom, Skype, or similar meeting programs via the USB Type-C connection to your personal computer. The HUB provides three bays, allowing multiple battery power supplies from two NP-F batteries and/or one V-Mount or G-Mount battery (batteries available separately).
Expandable System
The Solidcom C1 system allows you to link up to 7 remote headsets to the master headset without using a HUB. The C1 HUB base allows up to eight remote headsets and one wired headset to be used at once. Up to 3 HUBs can be cascaded with standard RJ45 cables, allowing for up to 24 remote headsets to be used at the same time.
