Hollyland Solidcom SE Pro 1.9GHz Wireless Intercom Kit with 9 Headsets
1 / 8
$2,533.00
Add to Wishlist
Features:
  • 400m Transmission Range
  • Dual-Mic Noise Cancellation
  • Supports Up to 11 Users
  • Dependable Mute Control
  • Dust and Water Resistance
  • 10-Hour Battery Life
  • 3.5mm Headphone Supported
  • Ready Out of Box
The Solidcom SE Pro is built for production teams that demand reliable and enhanced communication. Featuring a transmission range of up to 400 meters, dual-mic noise cancellation, and support for up to 11 users, it delivers crystal-clear audio even in challenging environments. With a 10-hour battery life and USB-C connectivity for convenient charging, it's perfect for fast-paced settings like video production and outdoor events. The system comes pre-paired for instant setup, and its water-resistant design ensures dependable performance wherever your work takes you.
Uninterrupted Communication, Every Time
Extended Transmission Range – Up to 400m
Stay connected with your team across large distances. The Solidcom SE Pro offers an impressive 400-meter communication range, delivering crystal-clear conversations even in wide and dynamic workspaces.
Advanced Interference-Free Connectivity
Adaptive Frequency Hopping ensures stable performance by automatically avoiding environmental interference. Coupled with operation in the 1.9GHz band, it effectively minimizes disruptions from crowded 2.4GHz frequencies like Wi-Fi and Bluetooth.
Dual-Mic Noise Cancellation – Pro Sound Sensation
Cut through the noise with dual-mic noise cancellation, designed to isolate your voice in the busiest environments. Whether you're on a bustling set or in an open outdoor space, your message comes through loud and clear.
With a wideband frequency response of 150Hz–7kHz, expect rich, detailed audio that elevates your communication to a truly professional level.
Supports Up to 11 Users – Scalable for Growing Teams
Whether you're starting small or managing a larger crew, the Solidcom SE Pro is ready. With support for up to 11 users, it's ideal for budget-conscious teams that need flexibility and room to grow.
Battery Life Estimates:
  • Remote Headset: Over 10 hours (with noise cancellation enabled)
  • Master Headset: Over 5 hours (with 5 remote headsets)
  • Master Headset: Over 4.5 hours (with 7 remote headsets)
Note: The Solidcom SE Pro is not compatible with the Solidcom C1, C1 Pro, or Solidcom SE Global Version.
Stay in control with dedicated TALK/MUTE switching and a quick-access boom mic mute feature. For hands-free convenience, the industry-standard PTT (Push-to-Talk) mode ensures smooth communication that fits your workflow.
Comprehensive Protection – Built to Withstand the Elements
Designed for real-world use, the Solidcom SE Pro is dust- and water-resistant, shielding against rain, splashes, and unpredictable conditions. Wherever the job takes you, you can count on solid, uninterrupted communication.
Stay Powered – 10-Hour Battery Life + Hot Swap Convenience
Get through long days with a 10-hour battery life on each headset. The detachable battery design allows for instant hot-swapping — just pop in the spare battery (included) and keep going.
Need more flexibility? USB-C charging lets you power up with a wall charger or power bank while still using the headset.
Connect Your Way – 3.5mm Headphone Compatibility
Prefer using your own headphones? The Solidcom SE Pro supports 3.5mm headphone connection via a Hollyland USB-C to 3.5mm adapter. Simply wear the headset around your neck and stay connected in comfort.
Note: Only compatible with the official Hollyland adapter (sold separately).
What's in the box:
1 x Hollyland Solidcom SE Pro 1.9GHz Wireless Master Headset
8 x Hollyland Solidcom SE Pro 1.9GHz Wireless Remote Headset
18 x Hollyland Li-ion Battery Pack HL-BAT770
1 x Hollyland Solidcom SE Pro 8-Slot Charging Base
1 x Hollyland USB-A to USB-C Cable
1 x Carry Case
$2,533.00
$2,533.00
