Hollyland Wireless Tally System (With 4 Tally Lights)
1 / 9
$1,142.00
Add to Wishlist
Features
  • Portable Wireless Tally System
  • 4 Tally Lights Included
  • Connect Tally Lights up to 2600' Away
  • Up to 16 Channels Supported
  • Smart Sequence Learning
  • Adaptive Frequency Hopping
  • Detachable Battery with 8-Hour Runtime
  • DB25, RJ45 & USB-C Connectivity
  • Tally Light & Battery Weigh Only 3.5 oz
  • Hard Shell Case Included
This Wireless Tally System from Hollyland is a portable, complete tally solution that includes four tally lights that can be connected up to 2600' away from the wireless host unit. Equipped with multiple ports that provide DB25, RJ45, and USB-C connectivity for compatibility with a wide range of switchers, the system boasts a powerful smart sequence learning function, adaptive frequency hopping, and support for up to 16 channels for future expansion of the system.
The sequence learning function of the system enables users to easily connect any switcher operating with high or low voltage levels to the system, employing a standard tally cable for wide switcher compatibility. Frequency hopping facilitates the detection of interference, enabling the system to automatically hop to a channel with less interference for a more stable and reliable transmission. A detachable lithium-ion battery pack included with each tally light provides up to eight hours of uninterrupted operation, and a hard-shell case is included for easy transport and storage.
Specifications:
General
Compatibility
Max Transmission Distance
2600' / 800 m
Sensitivity
<-115 dBm
Delay
<150 ms
Display
Panel Type
Not Specified by Manufacturer
Display Size
Touchscreen
No
Inputs / Outputs
USB I/O
1 x USB-A Female Input/Output
1 x USB-C Female Input/Output
Other I/O
1 x RJ45 Port for Tally Input
1 x RJ45 Port for Switcher Loop Out
1 x DB25 Port for Tally Input
2 x Antenna Connector
Wireless
Wireless
2.4 GHz Radio/RF
*Built-In
Power
Power Source
AC Adapter with Power Brick (Included)
Environmental
Operating Temperature
32 to 113°F / 0 to 45°C
Storage Temperature
14 to 140°F / -10 to 60°C
Physical
Color
Black
Dimensions
9.2 x 5.6 x 2" / 232.8 x 142.5 x 50.1 mm
Weight
2.6 lb / 1.2 kg
Hollyland Tally Light Specs
General
Compatibility
2,600' / 800 m
Sensitivity
<-115 dBm
Delay
<150 ms
Modulation
LORA
Wireless
Wireless
2.4 GHz Radio/RF
*Built-In
Battery
Battery Chemistry
Lithium-Ion
Maximum Battery Life
8 Hours
Environmental
Storage Temperature
Physical
Dimensions
3.1 x 2 x 1.5" / 77.8 x 50.5 x 37.4 mm
Weight
3.5 oz / 98.5 g (with Battery)
Hollyland Hard-Shell Case For Wireless Tally System Specs
General
Compatibility
Physical
Color
Black
Dimensions
20.3 x 13.8 x 8.5" / 515 x 350 x 215 mm
Weight
Hollyland Antenna For Wireless Tally System (Pair) Specs
General
Compatibility
Gain
4 dBi
Physical
Color
Black
Dimensions
10.4 x 3.9 x 1" / 265 x 100 x 25 mm
Weight
4.1 oz / 115 g
Hollyland 12V 2A DC 2.1mm Power Adapter Specs
General
Compatibility
Power
Power Source
Power I/O
1x Barrel Output
Center Tip Polarity
AC Input Power
DC Input Power
12 VDC at 2 A
Maximum Power Output
Physical
Color
Black
Dimensions
8.5 x 5.2 x 0" / 215 x 132 x 0.1 mm
Weight
5.29 oz / 150 g
What's in the box:
1 x Hollyland Tally Station
4 x Hollyland Tally Light
4 x Battery
1 x Battery Charger
1 x Carry Case
$1,142.00
$1,142.00
