LARK M2-USB-C Receiver (Shine Charcoal)
- Compatible with USB-C devices
- Plug and play
- Can be used while charging
Australia / English
Your cart is empty
$60.00
Default Title
$60.00
$60.00
Compatibility Wireless Tally System What's in the Box Tally Light*1 Li-ion Battery Pack 700*1...
Compatibility Wireless Tally System What's in the Box Tally Station*1 DC Power Adapter*2 Wire...
48 kHz/24-bit High Fidelity 3-Level Intelligent Noise Cancellation EQ & Reverb Adjustment Au...
Accessory for LARK A1
Feature 48kHz/24 Bit AI Noise Cancellation Quick Charging Clip-and-Go AI Voice Tuning AI Auto-L...
Get 5% Off Your First Order
Technical Support:
support.au.hollyland.com
Order Support:
