LARK MAX 2 - Hot Shoe Adapter
Accessory for LARK MAX 2
Australia / English
Your cart is empty
$65.00
Default Title
$65.00
$65.00
Hollyland 3.5mm Air Duct Earphone for Syscom 1000T and Mars T1000. 3.5mm four connector Clear v...
Features: Convert the 3.5mm TRS interface to a single XLR audio output for mixers, sound cards...
Hollyland SDI Cable (1000mm): A 100cm BNC cable for connecting devices that are further apart on ...
Get 5% Off Your First Order
Technical Support:
support.au.hollyland.com
Order Support:
