- 1 receiver x maximum 4 transmitters
- 1800ft transmission distance
- 0.07s ultra-low latency
- 4 pairs of SDI and HDMI outputs on the receiver
- Supports RS-422 and RS-485 connections
- Supports wireless tally feature |Auto channel scan on the receiver
Syscom421S-4TX&1RX
$10,588.00
Syscom221S-2TX&1RX
$6,398.00
Syscom421S-4TX&1RX
$10,588.00
NOTIFY ME WHEN AVAILABLE
$10,588.00
You Might Also Like
3.5mm TRS-to-USB Type-C Cable
Hollyland 12V 2A DC Adapter Power Supply Unit
Hollyland 2.4 & 5 GHz Thumb Antenna for Pyro (2-Pack)
